It can be done but IMO it is A LOT easier just to use the wire cutters. I think I'd rather use my teeth than one of them.
You two must be confused, your suposed to add fibre in to your diet
I always use my teeth for cheap speaker cable.
Quote from: micky d on March 07, 2008, 11:42:00 PMYou two must be confused, your suposed to add fibre in to your diet So that's where I've been going wrong! I always use my teeth for cheap speaker cable.
Seriously though, I always use the blade at a really acute angle, and just sort of whittle the cable sheath off
Quote from: micky d on March 07, 2008, 11:47:08 PMSeriously though, I always use the blade at a really acute angle, and just sort of whittle the cable sheath off Depends on how thick the insulation is to how i do it, i've got an automatic stripper that sees a fair amount of use for small to medium cables. If i'm stripping thick power cable though i use a knife and cut along the length i'm removing then peel it back and trim off around the circumference.
Quote from: Roadie on March 07, 2008, 11:49:28 PMQuote from: micky d on March 07, 2008, 11:47:08 PMSeriously though, I always use the blade at a really acute angle, and just sort of whittle the cable sheath off Depends on how thick the insulation is to how i do it, i've got an automatic stripper that sees a fair amount of use for small to medium cables. If i'm stripping thick power cable though i use a knife and cut along the length i'm removing then peel it back and trim off around the circumference.In my last job a large part of it was installing white goods which involved MANY plug removals (damn worktops!) and also cooker installations using 6mm cable. I used the same set of side cutters the whole time I was there but sadly broke then a few weeks ago.
Quote from: Benner on March 07, 2008, 11:35:45 PMIt can be done but IMO it is A LOT easier just to use the wire cutters. I think I'd rather use my teeth than one of them. Yup they're not the easiest things to use. As for the teeth method, it works really well for some cable but for others its just not possible! I find it easier to use my teeth on small diameter stuff than proper wire strippers.
