[Listed]Spyderco Endura FFG - USD 78.95
Guest · 1 · 181
EDCSource
  • Guest
on: December 01, 2012, 07:00:03 AM
Spyderco Endura4 Full-Flat Ground with Orange Handle The plain edge blade has a full flat-grind of premium VG-10 stainless stee. The blad features a thinner highly refined cutting edge and a larger 13mm opening hole. Added to the blades spine is slip resistant jimping. Phosphor bronze washers smooth out the open/close action and the clip is upgraded to a four-way tip-up, tip-down, left-or right-handed clipThe durable FRN (fiberglass reinforced nylon) handle has a bold Orange color. Molded onto the handles surface is Bi-Directional Texturing for slip-free tactile traction. Inside the handle are dual skeletonized stainless steel liners which strengthen the knife without additional weight and double as an anchor for external and internal components to attach through generating more sturdiness and rigidity.length overall8.75 (222 mm)blade length3.75 (96 mm)blade steelVG-10length closed5 (127 mm)cutting edge3.438 (88 mm)weight3.4 oz. (96 g)blade thickness.125 (3 mm)handle materialFRN
http://www.edcsource.com/auction_details.php?auction_id=114489
Total Receipts: $10.00
PayPal Fees: $0.69
Net Balance: $9.31
Below Goal: $290.69
 3%
