The Commander (LM Super Charge Mod)
ca Offline Metropolicity
  • Hack Virtuoso
Reply #60 on: December 22, 2012, 02:19:06 AM
Ok. Major update.
Spend sometime today doing some prelim assembly.
Transplanting the goods from the Charge TTi Commander into the new Wave Commander proved to be somewhat of an adventure. I remember why I liked the wave over the TTi, everything about it just more compact and rigid.
Here are some over all shots and I'll explain further.
Lets talk blade exchanger, the previously fitted BE Locked up great on the new wave body but a cut out needed to be made to accommodate it.
Why are the pivots different? They are actually pivots from a surge. Unlike the Charge, the wave's pivots are independent from the handles/scales. The increased thickness of the BE and scissors required me to use some longer barrel pivot pins. While the BE pivot was good as is, the one holding down the scissor abs blade needed a tiny bit of adjustment.
A great spacing when opened up. I'll be tweaking the grip plates and getting them done in stainless.
The inside tools aren't that crazy, I did however swap the standard rebar awl for my own concave edge one.
The otherside is a can opener (unknown replacement right now) and second bit driver.
And here's a random photograph of my dog wearing a hat.
Why stop now?
Shapeways - Metro's Q-branch:
spam Offline scrappy
  • Turd Bucket
Re: The Commander (LM Super Charge Mod)
Reply #61 on: December 22, 2012, 03:23:27 AM
looking good Eric
us Offline stealth007s
Reply #62 on: December 22, 2012, 05:55:05 AM
Very cute Eric!¡! Oh, and the new project looks to be coming right along.......................  :tu:
 :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Terry
  • Hack Virtuoso
Reply #63 on: December 22, 2012, 07:14:15 AM
Wanted to waste some time in the shop late on a Friday night.
Chucked up some 6061 and milled out some grips. The jimping isn't as nice, I only have 7/32 ball mills at the moment.
Here is fresh off the mill, test fitting.
After a 100 grit sand paper.
....and after a 400 grit wet sand, installed with doubled sided tape.
I used the blade profiles as a template. So the grips aren't protruding past them, and follow the curve.
The extra filler of the grips makes for a nice meaty grasp when using the drivers. It also solved the problem I was having with the blade exchanger digging into my hand.
« Last Edit: December 22, 2012, 07:18:47 AM by Metropolicity »
Why stop now?
de Offline lowtech
Reply #64 on: December 22, 2012, 08:30:21 AM
I really like the wave you made. seems a good all round tool combo. Your work is excellent like usual.
If those greips get available, i might feelthe need to buy my first leatherman, just to be able to use them.  ;)
  • Hack Virtuoso
Reply #65 on: December 22, 2012, 08:45:51 AM
Now that I know the general dimensions and extruded profile, I'll see about throwing them in CAD and RPing them in polished stainless. What am very curious about is if I can somehow mount the 1/8" ferro rod into the grips, I feel like they could be utilized somehow, but my attempts to make the T&T fit didn't quite work out.
Why stop now?
  • Hack Virtuoso
Reply #66 on: December 23, 2012, 01:11:22 AM
Did some playing around with the grips I made last night. Always nice to manually manipulate real metal instead of pushing pixels around.
Instead of trying to mill a dual slot for the T&T, I milled a single slot for the tweezer. This gave me a great idea of off setting the slot to one side for a later generation. Once offset, they won't interfere with each other when the pliers are open. I think I can also incorporate a pin when I go to CAD.
For now, a single slot for the tweezer will do for now.
Adding some double sided tape.
Stuck on!
The tweezers fit too, so this'll work for either or.
I was also racking my brain trying to figure how to add the 1/8" without compromising the body of the Wave. So I pulled a temporary, emergency solution: blue tack.
The BE slot has plenty of room for the rod, and it's kept in place and safe, until needed.
Why stop now?
Reply #67 on: December 23, 2012, 11:06:50 AM
they look excellent Eric. :salute:
pl Offline u99
Reply #68 on: December 23, 2012, 01:18:56 PM
I admire your creativity and inventiveness. Great modification, we can say that the Wave took on a whole new quality.
Reply #69 on: December 23, 2012, 01:47:13 PM
Looking great. :tu: If you know the name of that tape you used, model number or something, I'd love to know. :salute:
Reply #70 on: December 23, 2012, 03:12:44 PM
Love it, want it.
Love you, love your work.
Seriously Eric, you're a fracking genius :cheers:
england Offline Taxi Dad
Reply #71 on: December 23, 2012, 07:05:12 PM
just a thought, and i don't consider myself an expert, but if you want to add tweezers to a wave, the tweezers from a LM squirt fit nicely in the space were the pocket clip should go ! if you use the pocket clip/REMOVABLE lanyard ring you could poss. remove the fixed lanyard ring ???
ps. if anyone has a 'spare' set of them i'd be keen to buy them, PM me if you do  (wifey wants hers back ) ;)
  • Hack Virtuoso
Reply #72 on: December 23, 2012, 07:18:40 PM
Yah, that's the prime spot. I'll see what I can do, but right now it's fun to experiment!!
Why stop now?
Reply #73 on: December 23, 2012, 07:19:36 PM
obviously I didn't mean it for you oh great one, it was more for us lesser mortal types that don't posses your skills  :tu:
« Last Edit: December 23, 2012, 09:40:31 PM by Taxi Dad »
  • Hack Virtuoso
Reply #74 on: December 23, 2012, 10:43:37 PM
Lol! I am just like every other joe with a mill and lathe. ;)
Why stop now?
us Offline Outback in Idaho
Reply #75 on: January 10, 2013, 10:28:53 PM
Wow, where was I when you was making this?  :drool:
 :drool: Wants!  :drool:
¬ Outback in Idaho
us Offline redbaron
  • I've made some things
Reply #76 on: January 11, 2013, 02:44:36 AM
  • Hack Virtuoso
Reply #77 on: January 11, 2013, 03:23:01 AM
whats that cutout on the rebar plier head?
What cutout? If its the on the shoulder is where I tired to mill off a bit of it to see if I could fit the scissors in.
Why stop now?
us Offline tattoosteve99
Reply #78 on: January 11, 2013, 03:28:19 AM
Do you think the t&t piece would work on both sides at the same time?
  • Hack Virtuoso
Reply #79 on: January 11, 2013, 03:39:24 AM
I'll know when I get the next shipment I from shapeways. It's my first time printing in stainless so I don't know how the tolerances work
Why stop now?
Reply #80 on: January 11, 2013, 07:03:38 AM
Man, I was hoping for an update on this!¡!
:popcorn:
Terry
us Offline redbaron
Reply #81 on: January 11, 2013, 09:07:26 PM
Oh hey, I quoted the wrong pic, I would like to see more detail of the milled cutout
ca Offline scorpion008
  • I travel Light: Wave with a pocket clip
Reply #82 on: January 17, 2013, 12:31:04 AM
:popcorn:
Me too. This is my fave piece of Metropolicity's work.
  • Hack Virtuoso
Reply #83 on: January 19, 2013, 02:36:51 AM
STAINLESS UPDATE!!!
Yaaaahhhhh!!!! They are here!!
Along with the shears too!
I am surprised, I shouldn't be, it is stainless steel after all.
They are still a little wide (literally 1mm too wide) but these with a little work are swweweetttttttt!!
They won't close yet but they need to be milled to the right edge
The pin slot is still too tight but it was fun to try!
I need to physically alter these grips be before they go on the Commander but woo!
Why stop now?
Reply #84 on: January 19, 2013, 03:28:37 AM
You know, you make all these awesomely super epic mods, but how does this benefit you? I'm guessing you simply like modding as a hobby because you have made enough perfect edc tools to last a lifetime. Will you end up selling some of them to finance other ventures?
  • Hack Virtuoso
Reply #85 on: January 19, 2013, 03:44:14 AM
It is primarily a hobby, but it's also a mental exercise. I often get caught up on a project and need to move on to another project, even for just a bit to get my clouded mind clear of it.
I often make very specific tools for specific jobs. I am a product designer and wear a lot of different hats...so the more tools for more jobs the better!
Why stop now?
Reply #86 on: January 19, 2013, 04:34:37 AM
:popcorn:
Sent from Endor using Schlapatok
Terry
Reply #87 on: January 19, 2013, 04:38:01 AM
  • Turd Bucket
Reply #88 on: January 19, 2013, 06:14:19 AM
Eric
You should start a thread that contains pics of all the tools you have made. The entire collection.
Reply #89 on: January 19, 2013, 06:21:39 AM
And maybe market it. A DIY, just make sure buyers don't know they'll never be able to do any of it.
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $146.50
PayPal Fees: $7.89
Net Balance: $138.61
Below Goal: $161.39
46%
March Donations
