7075 alloy can be anodized just as bright as 6xxx aluminum. I did a lot stuff with this alloy.However, I found 6xxx aluminum to be the best alloy all around.
PTR, how slim do you think the CF scales could get as no outer liner alox replacements. I saw that you used the 2.5mm ones. Would 2.0 be strong enough?An what about thin steel liners? Strong enough?Cheers!
