Steel and 'Finishes'
us Offline tattoosteve99
Re: Steel and 'Finishes'
Reply #30 on: April 16, 2013, 12:33:07 AM
After a post from Stew
Removing rust with  Electrolysis  >:D
Most people use a 12v car battery charger, I have two but they are both out on loan  ::)
So after a little look around the mess that is my garage I came up with a 2amp 24v power supply,
this method produces hydrogen so only try it somewhere with good ventilation
I hung 4 x 4” nails (anodes +) inside a plastic tub and connected the – to the Axe head
The liquid is a tablespoon full of washing soda crystals dissolved in warm water
After about 8hours we have soup  :)
After a scrub in the sink  ;)
After a drop of linseed oil  :D
Just needs a sharpen and a bit of stick now
I hope that all makes sense  :salute:
Remember
-to Axe
+ to sacrificial steel
Please explain "washing soda crystals". And where the hell have I been to miss this ???
gb Offline Farmman
Reply #32 on: September 08, 2013, 10:20:26 PM
Time for a thread resurrection.  Just borrowed the vinegar from the kitchen.  Axe head is in having a bath. How long before I add the salt?
Reply #33 on: September 08, 2013, 10:40:33 PM
Now?
Salt is supposed to make it work better / quicker, probably?
Put the vinegar in the microwave for a min or two to warm it and stir the salt in (it can bubble over very quickly but leaves the microwave clean but smelly  ::)  )
I guess you will tell Laura its all my fault?   :facepalm:
Edit to add  ;)  And you should wait until shes gone out  before you wash all the black off in the kitchen sink  :rofl:
« Last Edit: September 08, 2013, 10:50:56 PM by sparky415 »
gb Offline Farmman
Reply #34 on: September 08, 2013, 10:43:43 PM
Ah bit late for the microwave as there is a steel axe sat in it. However I will add some salt.
Reply #35 on: September 08, 2013, 10:57:14 PM
Can't do any harm  :tu:
 :dwts:
 :D Good luck Mate
Reply #36 on: September 09, 2013, 12:34:48 AM
You know we need some pics right mate? :pok:
gb Offline Farmman
Reply #37 on: September 09, 2013, 08:29:43 PM
I must have got duff vinegar. Getting more tomorrow or possibly coke.
Reply #38 on: September 09, 2013, 08:47:53 PM
 :think: :think:
Whats the outcome Mark? I use ordinary value vinegar the cheapest I can find
You could try leaving it in another day and night?
« Last Edit: September 09, 2013, 08:54:04 PM by sparky415 »
gb Offline Farmman
Reply #39 on: September 09, 2013, 08:56:24 PM
Kind of removed some but has requires quite a bit of wire wool work too.
Reply #40 on: September 09, 2013, 09:08:56 PM
 :pok:  Chuck it back in Mate,
Just thinking, the steel wasn't oily was it?  :think:
And don't forget you have created vingaroon, stains everything  :whistle:
http://www.adamsleatherworks.com/vinegaroon-a-k-a-vinegar-black/
Reply #41 on: September 09, 2013, 10:18:16 PM
Great thread Tony.   :tu:   Not sure how I missed this one. Glad I've now found it. Lots of good info!     :)  Since I seem to have some rusty tools and axes.  I've spent a goodly amount of time working on axe heads with sanding sponges. Time well spent since I seem to enjoy it.     :D
« Last Edit: September 09, 2013, 10:20:36 PM by David »
Reply #42 on: September 09, 2013, 11:21:54 PM
Thanks David, I tried to get some useful stuff in one thread  :salute:
Feel free to add other 'Rusty' tips  :tu:
gb Offline Farmman
Reply #43 on: November 26, 2013, 09:47:33 PM
Now its gone nice and quiet on here. The vinegar trick did work on some footprints I had.  The axe must have some sort of surface protector on it
Sent from my Hudl HT7S3 using Tapatalk
Reply #44 on: November 26, 2013, 10:08:38 PM
 :pok:  Pictures?
Did you wash the black gunk off in the kitchen sink?  >:D
gb Offline Farmman
Reply #45 on: November 26, 2013, 10:54:06 PM
Kitchen sink! You have met the wife? I am still alive to be typing this.  No my garage has all mod cons including cold water collected from the rain water butt just outside the door. Pics will have to wait as I am now indoors and plan to stay that way.:-)
Reply #46 on: March 01, 2017, 09:17:29 PM
Everything you need to know about removing rust  :tu:
(Thanks Smashie   :salute: )
https://www.youtube.com/watch?v=zCuQquR-rzo
Reply #47 on: March 02, 2017, 08:24:01 AM
^^^    :D          :like:
Reply #48 on: March 06, 2017, 06:50:15 PM
Great thread  :like: :cheers: :tu:
Reply #49 on: March 06, 2017, 07:04:23 PM
Just like my garage, Full of rusty steel  :D
nz Offline Syncop8r
Reply #50 on: October 02, 2017, 09:12:01 AM
Is there such a thing as "too long" to leave steel in a vinegar bath?
Is there an optimum time or the longer the better?
Reply #51 on: October 02, 2017, 09:00:39 PM
Kinda Yes  :D
Take it out when the rust is gone, I know it's a silly answer but the vinegar will eat the steel when it has finished the rust (I forgot a round file for a few weeks and it wasted away  :facepalm: )
So put it in, leave it for a few hours then check it, repeat...
Over night will sort out most rust  :tu:
Wash the black gunk off in a sink but be careful as it will stain everything!  :ahhh
nz Offline Syncop8r
Reply #52 on: October 03, 2017, 12:39:56 AM
Kinda Yes  :D
OK, it has been 3-4 days so that will do then!
Oh, and I watched that video above, then part 2, then part 3 instead of going to the gym.  :facepalm:
au Offline TazzieRob
Reply #53 on: October 03, 2017, 08:30:57 AM
I have used a rust converter that you apply, leave on for 15-30 minutes, then wipe off with a damp cloth, followed by a methylated spirit soaked cloth, then a dry cloth. Seems to work quite well, but don't ask me how much it costs, as I can't remember!
Reply #54 on: October 04, 2017, 05:24:36 AM
I checked last night, my rust converter is Phosphoric Acid. The acid transforms the iron oxide rust into ferric phosphate.
Molasses contains phosphoric acid, so a similar result to the video with the cold chisels is what you can expect if you clean off the black ferric phosphate coating
« Last Edit: October 04, 2017, 06:22:42 AM by TazzieRob »
Reply #55 on: October 23, 2018, 10:07:43 PM
 :viking:  Bump
us Offline JBW1
Reply #56 on: October 24, 2018, 01:56:38 AM
Thanks for referring me to this thread Sparky! I think the rusty viniger gunk, used as a stain is genius! What better way to pay homage to the patina than use it to re stain your handles, haha. As far as vinegar goes, does the kind of vinegar make any difference? I had tried apple cider vinegar soak for rust, referred by you tube university. Supposedly works better than white vinegar? :think:
Reply #57 on: October 24, 2018, 07:05:11 AM
I have always used the very cheapest vinegar that I can find  :shrug:
I think that you should use try wire brush on your axe first, if you don't like that finish you can then try the vinegar
you can't get the old finish back after using the vinegar
