First attempt at Horn scales[....]... and yes I know there is a crack next to the caplifter. It made me say a bad word.
Nice job! You continue to impress! What is the thickness of the scales? How does the corkscrew feel in the hand (it looks to jut out a bit). The Phillips on your cf tinker mod seem to be just about flush with 2.5mm cr scales. Cheers
I like the exposed pins. Can you do that with any SAK or is it special? I really liked the way they looked on that CF one you just did. If it can be done on any one of them, can it be done with silver/ chrome(?) pins?
Quote from: stealth007s on December 29, 2012, 09:39:53 PMI like the exposed pins. Can you do that with any SAK or is it special? I really liked the way they looked on that CF one you just did. If it can be done on any one of them, can it be done with silver/ chrome(?) pins?It's possible in theory to do exposed rivets on almost anything. With a little messing around even on standard cellidor scales. On these horn scales I have used 1/8 O.D. copper tube with 3/32 I.D for bushes superglued through the scales and 3/32 brass rod for the pins. I came up with that idea after peening the first pin caused the scale to split as the end of the rod bent slightly as the head was being formed. Now the copper bushing holds the pin straight and allows the right amount of "squeeze" across the layers to stop any tool wobble.Silver pins can be made from Nickel Silver AKA German Silver which actually has no silver in it at all. "The usual formulation is 60% copper, 20% nickel and 20% zinc". WikipediaI have been trying to get hold of some but it just seems hard to find on this side of the world. Especially in the sizes I want
Taking notes.............This peening thing, is it hard to do? Should I practice before actually putting it into action? So many questions.............. Is there a video tutorial on this stuff? I hate reading
