Cabron fiber scales would be pretty sweet, but based on Syphs checking, the pins on the rangers are steel, so they are not that easy to remove. It would also suggest that Wenger feels brass is not up to the task for the rangers.NVM, it looks like the scales need some room due to the push button liner lock:
Quote from: papercut on January 11, 2013, 03:16:31 AMCabron fiber scales would be pretty sweet, but based on Syphs checking, the pins on the rangers are steel, so they are not that easy to remove. It would also suggest that Wenger feels brass is not up to the task for the rangers.NVM, it looks like the scales need some room due to the push button liner lock: Yeah, one scale needs additional room in one area, but there's still lots of potential for reducing the overall thickness I think
Quote from: 50ft-trad on January 11, 2013, 08:49:27 AMQuote from: papercut on January 11, 2013, 03:16:31 AMCabron fiber scales would be pretty sweet, but based on Syphs checking, the pins on the rangers are steel, so they are not that easy to remove. It would also suggest that Wenger feels brass is not up to the task for the rangers.NVM, it looks like the scales need some room due to the push button liner lock: Yeah, one scale needs additional room in one area, but there's still lots of potential for reducing the overall thickness I thinkIt's a liner lock! Why don't they add a cutout on the handle and let the user disengage the lock just like in any other linerlock knife out there?! IMHO it's not the lock button as much, as the pin bushings that require the giant slabs they call handles...
Quote from: Nikos on January 11, 2013, 08:53:30 AMQuote from: 50ft-trad on January 11, 2013, 08:49:27 AMQuote from: papercut on January 11, 2013, 03:16:31 AMCabron fiber scales would be pretty sweet, but based on Syphs checking, the pins on the rangers are steel, so they are not that easy to remove. It would also suggest that Wenger feels brass is not up to the task for the rangers.NVM, it looks like the scales need some room due to the push button liner lock: Yeah, one scale needs additional room in one area, but there's still lots of potential for reducing the overall thickness I thinkIt's a liner lock! Why don't they add a cutout on the handle and let the user disengage the lock just like in any other linerlock knife out there?! IMHO it's not the lock button as much, as the pin bushings that require the giant slabs they call handles...I hate blades where you have to put your thumb/finger under the line of travel to unlock it I'd be more likely to convert it to slippy if it was that much of a problem
Half stop...
