Wasn't there some gadget that sit between appliance and socket to measure the standby power? Somebody must have one to test a phone charger.
Quote from: jzmtl on January 11, 2013, 11:48:57 AMWasn't there some gadget that sit between appliance and socket to measure the standby power? Somebody must have one to test a phone charger..... and has anyone ever plugged one of thosn into another one of those, to monitor how much juice a monitor uses
I see my unplugging ethos raised a few questions, which I am not qualified to answer. But this I do know, as a general rule in life I try not to waste anything, including resources of any kind. So unless I get 100% proof that leaving something plugged in on standby is A-OK, I will err on the side of caution. It hardly takes much of my energy to do it, and I sleep better for it.
Hey, no-one wants their house burning down do they?! (unless you have a body you need to destroy... oh, wrong forum)
We will probably all be dead before most of the important resources run out, but if you have kids, grandkids etc and care in the least about the future of this planet, you make your choices accordingly.
Reduce the carbon footprint?¿? Save the world?¿? I'm actually doing the exact opposite
Quote from: stealth007s on January 11, 2013, 06:37:14 PMReduce the carbon footprint?¿? Save the world?¿? I'm actually doing the exact opposite You ago around KILLING trees, burning their leaf..... From the replies I assume most people do not have switches on their plugs, right?I can leave my charger plugged in all the time, but I switch the plug off when I am not using it, so it does not get hot etc.
ta taaaaaaa!!!!(Image removed from quote.)
Most folks I know who want to cut phantom power drains just plug a surge protector power strip with a power switch into the outlet, then turn off the surge protector. Putting the switch at the outlet is a decent idea, but climbing behind furniture to get to the switch might be a tad inconvenient.
I know this is getting off subject, but one of my pet peeves is bathroom exhaust fans. Nobody ever turns them off so they suck the heat out of the house and run till they quit working. So after replacing the the motor I also installed a timer on the switch so now it goes off after a few minutes.
Around these parts bathroom fans very often are controlled by hygrostats. Very convenient, turns itself on when you shower, then turns itself off when the bathroom is dry enough.
