MUT and MUT/EOD at US Cavalry
175GD · 24 · 4855
no Offline 175GD
on: January 21, 2013, 09:42:50 PM
Hello folks, I'm new at this forum and now I need some help.  Firstly, I find the MUT/EOD version demonstrated at US Cavalry a bit strange:  http://www.uscav.com/productinfo.aspx?productid=20691&tabid=548
Is this a prototype or some early production? Hint: 2 screws in the plastic filler under the carbon scraper. There are also other things, like the missing locking latch.
Secondly, I am a bit disappointed of my new MUT/EOD. Had never imagined a tool of this caliber would consist of any plastic parts. When my tool arrived, the driver bit retainer (the biggest of the plastic parts) was crushed. So now the tool is shipped back to LM via our national channels. Anyone else had any problems with the plastic parts of their MUTs?
us Offline stealth007s
Re: MUT and MUT/EOD at US Cavalry
Reply #1 on: January 21, 2013, 10:27:08 PM
First welcome to MTO :salute:
I didn't see anything different in the USC images :think: The lock latch is there and the screws are stainless instead of BO :think: As for the plastic parts, what would you have done differently :think: Too bad to hear that yours was crushed, but that's what the warranty is for I guess :think:
Terry
Reply #2 on: January 21, 2013, 11:09:53 PM
Can't answer that one for you, but welcome to MTO :cheers:
no Offline 175GD
Reply #3 on: January 22, 2013, 07:03:45 PM
Sorry, I ment the MUT shown in the video.  :whistle:
* MUT-USCAV.JPG (Filesize: 20.82 KB)
Reply #4 on: January 22, 2013, 08:33:50 PM
Same video that's on the LM MUT page. It was the first generation MUT.
*edit- There's actually a lot that's different about that tool from what's on the shelf today
« Last Edit: January 22, 2013, 08:37:51 PM by stealth007s »
Terry
no Offline 175GD
Reply #5 on: January 22, 2013, 08:56:53 PM
Ahh. Thanks. Not many produced of this first generation then?
May need to send my PST II also for some warranty rebuild. Its an 1195/0296 with broken points of the plier and a broken screwdriver after many years of use and abuse.
Is there any leather sheath for the MUT? I have a TripleK magazine pouch which seems to do the job, with some shaping thou.
Reply #6 on: January 22, 2013, 09:18:00 PM
Not sure about the production numbers on that one.
Landroza (a member of the forum) makes MUT holsters. Here's a link to the thread.
Terry
Reply #7 on: January 22, 2013, 10:02:30 PM
^ His sheaths are absolutely awesome :tu:
no Offline 175GD
Reply #8 on: January 25, 2013, 06:22:03 PM
Sent the MUT/EOD on friday, a week ago. Received a completely new MUT/EOD in the post today. And even with a new brown nylon sheath and sight wrench. Well done, Wenaas Sport & Fritid, Leathermans norwegian rep.  :tu:
no Offline 175GD
Reply #9 on: January 26, 2013, 05:20:37 PM
The new MUT has a handle (knife/saw side) that doesn't "lock" up against the plier in open position. Due to this, only the handle swings when trying to open the plier. The other handle indexes perfectly towards the plier.
Tried tightening the screws, improved slightly, but no felt indexing. Also lost the one-hand operation of the blade and saw with the screws tightened.
Is there a way to adjust to achieve the indexing function of the handle/plier link?
I know that the plier pivot may be a bit tight in a new tool, but since one of the handles totally lacks the indexing function there might be a fix for this  ???
Reply #10 on: January 26, 2013, 07:17:32 PM
Sorry to hear you are having problems with this Mut too 175GD :(  From your description, it sounds like the one handle is not "wedging" when in the fully open position..? :think:
Reply #11 on: January 26, 2013, 07:39:15 PM
Sorry about your mut I'm sure lm will sort it for you  :tu: welcome  :cheers:
no Offline 175GD
Reply #12 on: January 26, 2013, 07:54:32 PM
Correct, J-sews. It it this wedging function that needs to be tightened up. Impressed that you managed to understand my norwenglish  :salute:
I  think I then should remove the plastic part and give the handle a blow with a hammer?
But I guess it isn't the softest steel they have used here?
Zed: I know LM would correct this for me, but it seems to be such a minor issue that I should be able to correct it myself.
Can anybody tell which diameter blasting caps the MUT is designed for? I know other LM tools with crimper has had some problems with european 7mm blasting caps. I haven't tried crimping blasting caps yet with the MUT.
Reply #13 on: January 26, 2013, 08:39:54 PM
Not to worry about your english 175, it is superb. :salute:
I would try the hammer trick, only be very careful. Perhaps try using a hammer and punch for better control? The face of the "punch" should be rounded somewhat, so it will not leave a deep scratch. :think:
Do you have anything like that at hand?
no Offline 175GD
Reply #14 on: January 26, 2013, 09:01:12 PM
Yes, I think I could use a brass punch and place the MUT on a mini anvil. Thanks for your advice.
Reply #15 on: January 26, 2013, 09:06:28 PM
Brass is a great idea! Good luck, and let us know how it goes :)
As regards the cap crimper, I have no idea. Blasting caps are not generally available here, and I have never seen one. As a matter of fact I did not even realize they are made in different sizes  :-\
no Offline 175GD
Reply #16 on: January 26, 2013, 10:35:20 PM
"Blasting caps are not generally available here, and I have never seen one."
-What do you guys do for fun then?  :pok:
Reply #17 on: January 27, 2013, 04:15:17 AM
Not typically in different sizes. The caps we use in the military are all the same size.
Terry
no Offline 175GD
Reply #18 on: January 27, 2013, 08:31:10 PM
Tried the hammer trick. But material is too "springy". Will let LM have the tool back to have it corrected.
Reply #19 on: January 27, 2013, 08:38:42 PM
Dang. :(
no Offline 175GD
Reply #20 on: February 10, 2013, 10:03:54 AM
The replacement (2nd) MUT/EOD arrived a few days ago. This one passed the quality control  :salute:
no Offline Grathr
Reply #21 on: February 10, 2013, 04:04:16 PM
LM warranty rocks!
And a somewhat delayed Welcome to the forum!  :D
Reply #22 on: February 10, 2013, 05:11:35 PM
I'm glad you got a good one. :tu:
Reply #23 on: February 10, 2013, 06:59:23 PM
Glad you finally got a good one.
