And wouldn't it be better if you had both a full plain edge and a full serrated edge?
Ok , My turn to chime in... Lynn I personally have to disagree.... I work around boats,Having my Kershaw Leek with the CE is indispensable, I simply could not do without it. Cutting through dry rope, manila, polymer and a few others is much easier with serrations. I need the plain edge also during the day. Just my opinion.
Quote from: Monrogue on January 23, 2013, 02:35:44 PMQuote from: Metropolicity on January 23, 2013, 07:05:26 AMJust made a serrated edge for my squirt, even the tiny tools need SE and PE!! (Image removed from quote.)Nice job Metro You never cease to amaze me with the mods I've seen from you so far here Thank you! I mounted this morning. Looks and is super useful. Full SE for life!! (Image removed from quote.)
Quote from: Metropolicity on January 23, 2013, 08:34:04 PMQuote from: Monrogue on January 23, 2013, 02:35:44 PMQuote from: Metropolicity on January 23, 2013, 07:05:26 AMJust made a serrated edge for my squirt, even the tiny tools need SE and PE!! (Image removed from quote.)Nice job Metro You never cease to amaze me with the mods I've seen from you so far here Thank you! I mounted this morning. Looks and is super useful. Full SE for life!! (Image removed from quote.)Nice job, it looks pretty cool What tool did you replace with that new serrated blade?
Quote from: Monrogue on January 24, 2013, 03:57:12 PMQuote from: Metropolicity on January 23, 2013, 08:34:04 PMQuote from: Monrogue on January 23, 2013, 02:35:44 PMQuote from: Metropolicity on January 23, 2013, 07:05:26 AMJust made a serrated edge for my squirt, even the tiny tools need SE and PE!! (Image removed from quote.)Nice job Metro You never cease to amaze me with the mods I've seen from you so far here Thank you! I mounted this morning. Looks and is super useful. Full SE for life!! (Image removed from quote.)Nice job, it looks pretty cool What tool did you replace with that new serrated blade?I replaced the old SE blade I made. (Image removed from quote.)
Oh wow, that old SE blade looks vicious How well did it work?
Quote from: Monrogue on January 24, 2013, 06:36:45 PMOh wow, that old SE blade looks vicious How well did it work?Too well. I was worried about the "teeth"Break off.
I like combo because it looks cool. That's right!
Quote from: kmanct3 on January 24, 2013, 12:01:54 AMOk , My turn to chime in... Lynn I personally have to disagree.... I work around boats,Having my Kershaw Leek with the CE is indispensable, I simply could not do without it. Cutting through dry rope, manila, polymer and a few others is much easier with serrations. I need the plain edge also during the day. Just my opinion.+1 !!!Quote from: Syph007 on March 19, 2013, 05:59:26 PMCombo edges are more of a sales feature to sell the knife, rather than a use feature.Yes full serrations can aid in rope cutting, but mariners of old used sheepsfoot style blades for most rope cutting. Yout put the blade on top of rope, on some wood, and hit with a hunk of wood.. rope cut.The only place I personally felt a serration is useful is in the kitchen to cut my bread, and as a rescue blade.Now thats not to saw have 2 blades, one plain, one serrated isnt a bad idea, that's the best of both worlds, instead of a combo edge, the worse of both worlds. Sailors of old had to cope with wires and ropes of old i think. And you cannot lay on a piece of wood a line that is in full tension and needs to get cut suddenly.
Also worth remembering that a line under real tension will part far more easily that one that isn't.
Quote from: Gareth on March 19, 2013, 07:16:13 PMAlso worth remembering that a line under real tension will part far more easily that one that isn't. True, even easier if you have serrations on your blade!
On the Wave, with your thumb on the blade, just before deploying it, you can feel the area just over the thumb hole. The serrated blade has notches there, and the plain one doesn't. You don't even need to look to know which blade you're about to open.
