Corkscrew ?
us Offline colt 1911
Corkscrew ?
on: February 06, 2013, 03:45:59 AM
What are the uses for this little bugger other than pulling corks ?
CHEERS
Offline jrp316
Re: Corkscrew ?
Reply #1 on: February 06, 2013, 04:44:08 AM
It's a pretty good tool for undoing stubborn knots...I've heard it's good to play out fishing line, but I'm not sure how that'd be done.
spam Offline J Mackrel Jones
Re: Corkscrew ?
Reply #2 on: February 06, 2013, 05:17:03 AM
"Corkscrew - Very handy for untying too-tight knots: Get the point in between the cords like a mini-marlinspike, pull to loosen, do again elsewhere in the knot, until the knot can be undone.
- Can be used to push leather lacing, heavy thread, or fishing line through a small hole, as in repairing the seam of a hiking boot.
- Will hold a sewing needle stored between the corkscrew and the adjacent divider. But it is easy to forget the needle is there and lose it when opening the corkscrew. A short needle wrapped in paper can be stored down the center of the coil.
- Hold or retrieve tiny loops of thread or line while sewing, stringing beads, making jewelry."
   other improvised uses also:  p 157 SAK Owner's Manual  - buy the book !
us Offline Outback in Idaho
Re: Corkscrew ?
Reply #3 on: February 06, 2013, 05:25:53 AM
  Holds a pen. Corkscrew feels better. Used a Smith's Pocket Pal round file to gently make a small groove for the pin to fit more straight.
  But then too so does the package hook.
  Also holds a mini-driver. Is an unconfirmed rumor that the pin can be removed and replaced with a Leatherman mini-driver for both standard & phillips heads.
  Used Shoe Goo to make mine stick better, oiled the corkscrew prior.
  Also the mini-driver has another use that just an ordinary small screwdriver. Magnetize it to make a suspended compass.
  Also rumored to be a good knot untier and paracord grabber. Can also screw it into something and use the knife as a hangar. You might be able to thread paracord around it and use for a miniature grappling hook.
¬ Outback Idaho
Re: Corkscrew ?
Reply #4 on: February 06, 2013, 05:26:33 AM
Think i will, thanks for the info  :tu:
CHEERS
Re: Corkscrew ?
Reply #5 on: February 06, 2013, 05:32:44 AM
  Also rumored to be a good knot untier and paracord grabber. Can also screw it into something and use the knife as a hangar. You might be able to thread paracord around it and use for a miniature grappling hook. (Image removed from quote.)
AWESOME ! sums that one up !
CHEERS
se Offline Northern Geek
Re: Corkscrew ?
Reply #6 on: February 06, 2013, 12:35:25 PM
Check out this thread: 42 Uses For the Corkscrew 8)
Re: Corkscrew ?
Reply #7 on: February 06, 2013, 03:46:33 PM
CHEERS
Re: Corkscrew ?
Reply #8 on: February 06, 2013, 08:23:27 PM
My most common use for it is untying the laces of my hiking boots.  I also use the mini-driver regularly as my reading glasses have a screw in them that loosens up a lot.  (Yes, that means I do actually have a screw loose! :D But, we knew that already, didn't we?  :whistle: )
us Offline Nhoj
Re: Corkscrew ?
Reply #9 on: February 06, 2013, 11:01:14 PM
Drill out the dirt that is stuck in the end of a tent stake
« Last Edit: February 06, 2013, 11:06:39 PM by Nhoj »
