My experience with scissors on 93mm knives are similiar.If you use Solo springs you can't rest the scissors on the spring. The scissors' handle is the thing that defines the position of the locked tool. When grinding the solo spring to create a ramp where the handle slides along you have to be careful not to remove too much material or the tool will sit too deep inside the construction.What I found is that the sweetspot for the ideal position does not a allow a full snap from around 50°. It stops due to the rest of the material that's kept on the spring to allow for a nice positioning. However, between 0° and 30° I get a full snap. Syph is right about the kinds of scissors, the older ones work better. I think the only 100% solution are his custom springs.
I have a pair of riveted scissors with the fat handle. Those have a steel rivet.Maybe that's the disinguishing point with the modern ones having silver nickel/brass rivets?
Dammit.
