All this talk of scissors has me thinking...Can wingman scissors take the place of the saw?(Only thinking out loud, Breezy - don't worry!)
Quote from: mvyrmnd on February 19, 2013, 10:45:15 AMAll this talk of scissors has me thinking...Can wingman scissors take the place of the saw?(Only thinking out loud, Breezy - don't worry!) Surge scissors are better!
It's here!It arrived this afternoon, and I love it.I realised that I have, in my default setup, a 00,0,1,2 and 3 phillips driver. Just perfect for a computer tech Thanks Breezy!
Quote from: mvyrmnd on February 19, 2013, 10:45:15 AMAll this talk of scissors has me thinking...Can wingman scissors take the place of the saw?(Only thinking out loud, Breezy - don't worry!)Yes! They do fit. I saw them in a mod once. I think all you needed to do was widen the pivot hole a bit an slowly regrind the locking face for the liner lock. I've said it before but I loath the wingman/sidekick so much that no part of any of those tools would end up in one of my mods I don't like them so much that I don't even give them as gifts!!
Well, I'm calling this the TTXi... If I add scissors it'll need an S in there...So will it be the TTXSi or the XTiTS?
looks good! what method did you use?
Quote from: bmstrong on February 18, 2013, 10:04:29 PMIs there any way to have a Rebar head with the Charge bodies AND the scissors without any modifications? With out the scissors I'm lost. Without the Rebar head and replaceable wire cutters I have no interest in the Charge. Dilemma.the key is "without any modifications". the pic below shows the scissors on my ReCharge (top) compared to the stock scissors on a Charge TTi.(Image removed from quote.)as you can see, there was some grinding to be done (I used a dremel), but I'd rather sacrifice a bit of length on the scissors than potentially compromise the structural integrity of the Rebar plier head. the other option is to leave the scissors as-is, and have a slight gap in the handles (the tool won't close all the way).
Quote from: Breezy12 on February 19, 2013, 06:35:20 AMQuote from: bmstrong on February 18, 2013, 10:04:29 PMIs there any way to have a Rebar head with the Charge bodies AND the scissors without any modifications? With out the scissors I'm lost. Without the Rebar head and replaceable wire cutters I have no interest in the Charge. Dilemma.the key is "without any modifications". the pic below shows the scissors on my ReCharge (top) compared to the stock scissors on a Charge TTi.(Image removed from quote.)as you can see, there was some grinding to be done (I used a dremel), but I'd rather sacrifice a bit of length on the scissors than potentially compromise the structural integrity of the Rebar plier head. the other option is to leave the scissors as-is, and have a slight gap in the handles (the tool won't close all the way). is there the chance to use instead of scissors the Rebar awl in the Charge?
Quote from: antouant on March 20, 2013, 09:25:54 PM is there the chance to use instead of scissors the Rebar awl in the Charge?Yes metro has done it.
Quote from: tattoosteve99 on March 20, 2013, 09:56:15 PMQuote from: antouant on March 20, 2013, 09:25:54 PM is there the chance to use instead of scissors the Rebar awl in the Charge?Yes metro has done it.I have 2 different awls I've been meaning to try to fit in the ReCharge -- one from a Rebar, the other from a Core. maybe this weekend if fI find some time. if I remember correctly, they both require some grinding to fit properly, but Metro would certainly know best.
You could also grind down the flat driver to an awl. I did it on my Charge, not the prettiest job, but it really works
