skeletool CX scam?
us Offline baja820
skeletool CX scam?
on: February 26, 2013, 05:45:03 AM
I ordered a Skeletool cx from Amazon. It was sold to me as "new". This is how it arrived:
Is it possible that the 154cm blade is simply not marked or is someone trying to sell me a cx with a 420hc blade?
God made man but Samuel Colt made them equal.
us Offline Outback in Idaho
Re: skeletool CX scam?
Reply #1 on: February 26, 2013, 06:24:49 AM
  Could be possible the CM154 marking never got applied. Wished was a easy way to check the hardness of steel.
  Can sort of tell the hardness of the steel when sharpening with a Spyderco TASM. That comes with years of use though. Physical looks don't think you can tell the differences.
¬ Outback Idaho
ca Offline Metropolicity
  • Hack Virtuoso
Reply #2 on: February 26, 2013, 06:50:36 AM
The 420 blades are stamped and the 154cm ones are laser cut. The edges of the blade should have sharper corners on a 154 than on the 420.
Also, there are no known PE 420 Skele blades, only came in CE. The 154 was the only one that was available in either the CE or PE.
I all likely hood, the laser etching was missed on this one.
Why stop now?
Shapeways - Metro's Q-branch:
us Offline baja820
Reply #3 on: February 26, 2013, 06:53:24 AM
Thanks Metro, good info. :tu:
ca Offline jzmtl
Reply #4 on: February 26, 2013, 07:19:14 AM
When skeletool first came out 420HC is PE whereas 154cm is CE. That was a few years back though so someone having a new 420HC PE to swap onto this one is pretty unlikely.
us Offline SAKnight
  • 5.0 HO
Reply #5 on: February 26, 2013, 07:23:12 AM
Just a guess, but it looks like it was ground down from a ce. The ce blade on my skele and freestyle both have,for lack of  better term, a mini choil between the first hole and the thumb hole. This one does not, as theblade appears to have less belly, hence my hypothesis. Thoughts?
ca Offline armèe-suisse
Reply #6 on: February 26, 2013, 07:25:09 AM
Here's mine Skeletool 420 PE! :P
ca Offline jzmtl
Reply #7 on: February 26, 2013, 07:39:05 AM
The CE on those are pretty deep, so if you ground them off you wouldn't have much of a blade left.
Take a look at the edges of holes on blade, as metro said you should be able to tell the difference between a punched hole and laser cut hole. The former has inward rounded edge on front but sharp edge on the back, whereas lasered are 90° sharp on both sides.
  • Hack Virtuoso
Reply #8 on: February 26, 2013, 07:48:44 AM
Why stop now?
us Offline baja820
Reply #9 on: February 26, 2013, 03:50:22 PM
Upon closer inspection it would appear this is laser cut not stamped.
Reply #10 on: February 26, 2013, 10:38:31 PM
  Good find on you & Metro!  :D   :tu:
¬ Outback Idaho
