I do have a Sog but what if all my tools melt!! I'll try these out first and see what happens.
I don't understand how rust works. Seems like its not the water itself that makes stuff rust, its the water drying off. Like if I get my shotgun wet, as long as I bring it inside and wipe off the water, its fine. But if I let the water evaporate off on its own there are little speckles of rust. And also rust rings around the edges of wherever each little droplet of water last was.
IMO you should use tools that are of the same finish. That way, you are creating a fair test between both of the manufacturers.Looking forward to seeing your results.
Quote from: Benner on April 06, 2008, 05:11:46 PMIMO you should use tools that are of the same finish. That way, you are creating a fair test between both of the manufacturers.Looking forward to seeing your results. Ben you beet me too it Myself I wouldnt do a BO against a naked Steel finnish , just doesnt seem fair .Dunc
whatda ya mean, so many say LM is the "Best!"
