Unless you desperately need the pliers I would go Ranger. For a "small" tool the xe6 is actually pretty massive.
Quote from: Suveges on April 10, 2008, 01:30:31 AMUnless you desperately need the pliers I would go Ranger. For a "small" tool the xe6 is actually pretty massive. Agreed,I had an xe6 for awhile and I found it just too bulky and heavy for pocket carry.I'd go with a Ranger,and have you considered adding either a Gerber Clutch or Squirt P4,if full size pliers aren't a requirement.
Quote from: Bison56 on April 10, 2008, 03:55:39 AMQuote from: Suveges on April 10, 2008, 01:30:31 AMUnless you desperately need the pliers I would go Ranger. For a "small" tool the xe6 is actually pretty massive. Agreed,I had an xe6 for awhile and I found it just too bulky and heavy for pocket carry.I'd go with a Ranger,and have you considered adding either a Gerber Clutch or Squirt P4,if full size pliers aren't a requirement.That is probably your best bet. You can pick up Clutches pretty cheaply and twinned with your SAK you are pretty much covered. I often carry mine or the Shortcut as they are so small they don't get in the way.
Thanks all. To be honest the Juice is about as small a pliers size as I want to go, i'm not too impressed with the really small plier tools.I've been carrying the Juice for the last few days, and I think i'll stick with it. I have both so I may try the Ranger next week. I'm always a lttle surprised when I hear of folk rejecting the Juice because of it's size & weight, I can't say I notice it at all. I wear it on my belt next to my phone which sticks out a but further, so the Juice pouch is hardly noticed.
