Surface rust on brushed stainless MT - Removal ideas needed
tosh · 9 · 3337
gb Offline tosh
I've just gone and purchased a Kershaw A100 MT  :think:
It's used but judging by the pictures seems to be very well intact, nothing seems to be broken off!
However, it seems to have surface rust and I'm 100% certain it will come up good. My problem is the brushed stainless finish - I don't want to create "highlights" on it by the usual cleaning methods.
So, I'm wondering if I could just soak it in petrol?? diesel? WD40?? etc etc for a few days and gently brush it with an old toothbrush. I can't see a problem arising from this, but if there is one I'd like someone to advice me now before I go and ruin the finish.
Anybody??
P.S It's also pouchless, does anyone have one for sale?? (I've already placed an ad in the "wanted" section)
us Offline stealth007s
Re: Surface rust on brushed stainless MT - Removal ideas needed
Reply #1 on: April 13, 2013, 11:07:34 PM
If you could get your hands on some 3 in 1, I think that may do it for you.
Terry
gb Offline tosh
Reply #2 on: April 13, 2013, 11:19:37 PM
Hi Stealth'
3 in 1 is available here in the UK, But I would've assumed it was too thick to penetrate when compared to petrol (gas), diesel or WD40.
Still, I'm here to learn, if 3 in 1 works then that's what I'll try.
Cheers  :salute:
ca Offline jzmtl
Reply #3 on: April 14, 2013, 12:40:36 AM
Brass wire brush.
There's also the homemade chemical rust remover but I'm not 100% sure it's safe.
Reply #4 on: April 14, 2013, 05:08:12 AM
The finish on most Leatherman tools is what I call "brushed", whereas the finish on your Kershaw (and most Gerber multitools for instance) are what I call "bead blasted."  But regardless of how the finish was accomplished, it can be a bugger to match up to when doing rust spot removal. :-\
The important thing is to NOT make a shiny spot. (once you do, it's a royal pain trying to get it dulled back down again) I use a fine wire brush to remove the rust, but I don't "brush" with it in the normal way. I sort of whack the ends of the bristles repeatedly against the rust spot. Eventually the rust is gone, and the metal is silver-y again but with no lines or grain direction. (if that makes sense)
gb Offline tosh
Reply #5 on: April 19, 2013, 10:12:30 PM
Well, I decided to have a go at the white vinegar and baking soda approach - must say I will definately do it again. below are before and after pictures.
Please tell me what you think.
* multitools 001 (Large).jpg (Filesize: 129.1 KB)
* multitools 002 (Large).jpg (Filesize: 92.55 KB)
* multitools 008 (Large).jpg (Filesize: 72.12 KB)
* multitools 009 (Large).jpg (Filesize: 51.86 KB)
gb Offline tosh
Reply #6 on: April 19, 2013, 10:17:09 PM
And now after a 3 day soak with daily rub using a soft paintbrush...
After these pics were taken the battery went flat...Doh. I haven't yet charged it, but I have continued rubbing the remaining "spots" with a cotton wool bud soaked in vinegar and baking soda and surprisingly most has now come off.
It was never going to come up mint, so I wiped it down, put it in a pre heated oven for 30min then removed it and took it into the garage where it was totally soaked in WD40 then left to cool down overnight. I'll upload a pic sometime over the weekend.
I'M STILL SEARCHING FOR A KERSHAW POUCH.... ANYBODY???   :pok:
* multitools 010 (Large).jpg (Filesize: 157.33 KB)
* multitools 011 (Large).jpg (Filesize: 101.01 KB)
* multitools 012 (Large).jpg (Filesize: 117.27 KB)
* multitools 013 (Large).jpg (Filesize: 100.74 KB)
« Last Edit: April 19, 2013, 10:27:45 PM by tosh »
Reply #7 on: April 21, 2013, 04:01:11 PM
Looks much improved Tosh! :salute: Some day I will need to give that method a try. :)
au Offline gregozedobe
Reply #8 on: April 21, 2013, 04:11:12 PM
That is a big improvement on how it was when you got it - well done  :tu:
None surplus to my requirements at the moment, but if I ever find a genuine Kershaw Leather sheath/pouch I may be able to spare a nylon one.  Unless I happen to buy yet another A100 without a sheath in the meantime, which is a distinct possibility.
