The rebar is not really one of leathermans good tools
My Rebar was a little tight & I had too loosen one of the fasteners/bolts on one side I would probably return it too Target mate & get a good one
Quote from: Kingcollin on April 16, 2013, 03:12:08 AMThe rebar is not really one of leathermans good toolsBLASPHEMY!!
I did! My new one is a lot better!!
If this tool has the same knurled bolt construction as the one shown on the Leatherman website, then you just grab that knurled bolt on each side of the tool with pliers, and tighten or loosen as needed. The initial movement of the bolt may be difficult due to loctite on the bolt. Otherwise, it's really just that simple.
Quote from: sawman on April 16, 2013, 07:24:32 PMQuote from: Kingcollin on April 16, 2013, 03:12:08 AMThe rebar is not really one of leathermans good toolsBLASPHEMY!! I second this X4
Quote from: mikekoz on April 16, 2013, 08:10:16 PM I did! My new one is a lot better!!Glad you got a good one. I like and use my Rebar quite a bit.
The cheapest I've found the REBAR for is $36.49 now on Amazon.
Quote from: sawman on April 17, 2013, 02:12:07 AMThe cheapest I've found the REBAR for is $36.49 now on Amazon.$12 NIB at a flea market. >.>
