Saying the Rebar isn't good after having a bad one is a little shortsighted. I understand first impressions are usually a big deal, but you have only dealt with one unit, whereas EVERYONE else here has been happy with theirs, at least as far as quality goes. It might not be everyone's favorite, and it does have it's shortcomings, but I believe the majority here is more on the right track. Try the Rebar out again, and if it's a dud the second time then you might have a better foot to stand on when claiming it isn't one of LM's better tools.
... Several people on this thread have stated that the Rebar is not a quality tool, or it is not as good as it should be, but nobody can say why! Has anybody ever used one for a period of time and had it fall apart? Is the knife dull? Have the pliers broke? I have not used mine yet, but it appears solid like my other Leathermans.
I feel bad for those who received a bad one. I must say that for the prices LM charge, everything should be close to Vic quality, and I'm sure it's possible, you they just need to run their company properly. Maybe Tim LM should tour the Vic factory and take down a few notes and come back and fix LM.
Actually now that you mention it, one of the rivets on mine was not fully peened as well, and I had to finish the job. The rivet that holds the part on in top gears pic above that fell off. Thats more quality control issues, but I hope they have sorted it by now.I havent used mine much, so now I think I'll give it a good work out and go over to make sure its all solid. The problem with too many MTs is that they cant all be daily users.
My Rebar also came with a slight problem like the OP. All the tools on one side are loose and all the tools on the other side are tight. I debated sending it back, but at this point it's not worth the hassle to send it back to possibly get another in the same condition. With that said I still really enjoy my Rebar.
Quote from: mikekoz on April 18, 2013, 12:29:35 PM ... Several people on this thread have stated that the Rebar is not a quality tool, or it is not as good as it should be, but nobody can say why! Has anybody ever used one for a period of time and had it fall apart? Is the knife dull? Have the pliers broke? I have not used mine yet, but it appears solid like my other Leathermans.I was very excited about the Rebar and got myself one on the first day they were available in the local store, being a huge fan of the ST300 I thought the Rebar would give me a smaller alternative for the "bulky" ST300. So I think I can say I really liked the concept of the Rebar and bought it with the intention of using it for EDC. After two days of just looking at it and taking pictures this happened ...You can read the complete story here.I must say I really liked it, untill it fell apart on me, and the second one I got had the problem with the handles being way of. Anyway, I already told my story in another topic, so I won't start again here.
Quote from: sawman on April 18, 2013, 04:32:48 PMI feel bad for those who received a bad one. I must say that for the prices LM charge, everything should be close to Vic quality, and I'm sure it's possible, you they just need to run their company properly. Maybe Tim LM should tour the Vic factory and take down a few notes and come back and fix LM.My first Rebar was fine as well, but I'm just too anal about the handles and couldn't get past it. However, since you mentioned Vic, I had the same handle unevenness with my Spirit. I sent it back (Amazon) and got another that had the same problem, just not as bad as the previous one. Then some time later, I ordered one for a facilities guy here at work and it had the same issue. I've heard of others with this issue as well. It bugs me, but it's not worth any more hassle to try to get it fixed.
Quote from: Monrogue on April 18, 2013, 04:45:28 PMQuote from: sawman on April 18, 2013, 04:32:48 PMI feel bad for those who received a bad one. I must say that for the prices LM charge, everything should be close to Vic quality, and I'm sure it's possible, you they just need to run their company properly. Maybe Tim LM should tour the Vic factory and take down a few notes and come back and fix LM.My first Rebar was fine as well, but I'm just too anal about the handles and couldn't get past it. However, since you mentioned Vic, I had the same handle unevenness with my Spirit. I sent it back (Amazon) and got another that had the same problem, just not as bad as the previous one. Then some time later, I ordered one for a facilities guy here at work and it had the same issue. I've heard of others with this issue as well. It bugs me, but it's not worth any more hassle to try to get it fixed. IIRC, the Spirit handles are always slightly "misaligned" due to the way they are designed. I use misaligned in quotes, as it seems to me to be a by-product of how the handles are assembled.As I don't have my Spirit in front of me, I may be mis-remembering, though.Even though I didn't keep it, the Rebar was the first LM that made me seriously consider keeping it. I still may pick up one now that they are so cheap on Amazon. The main attraction to me is that it was the first LM that I could get the tools deployed without breaking nails, or using another tool to get them out. I've wanted to like the wave style tools, but the stubby drivers are a non-starter for me. Now, the Rebar philips in a Wave, that would be
I don't like loose tools! It's dangerous to have sharp edges slipping out. Loose pliers I do like! When your using tight pliers one handed, you have to grip the top handle with your thumb and prize the bottom handle open with the back of your fingers. With loose pliers just relax the fingers the bottom handle opens and re-grab ( if this makes sense). It's why I like the gerber mp600, very usable loose pliers.
