It's actually pretty nice- it's rock solid and functional. Well worth the few bucks for it.Def
Isn't there a wider sheath you need to get in order to fit the Spirit AND the ratchet set into it?
Quote from: J-sews on April 14, 2008, 03:54:50 AMIsn't there a wider sheath you need to get in order to fit the Spirit AND the ratchet set into it?I believe so. when I asked felinevet about it last night he said the set he has has a sheath that holds both the bits/ratchet and spirit.Brett
Quote from: bdws1975 on April 14, 2008, 03:57:03 AMQuote from: J-sews on April 14, 2008, 03:54:50 AMIsn't there a wider sheath you need to get in order to fit the Spirit AND the ratchet set into it?I believe so. when I asked felinevet about it last night he said the set he has has a sheath that holds both the bits/ratchet and spirit.BrettAh good, you are already aware of it then.
Quote from: J-sews on April 14, 2008, 03:58:02 AMQuote from: bdws1975 on April 14, 2008, 03:57:03 AMQuote from: J-sews on April 14, 2008, 03:54:50 AMIsn't there a wider sheath you need to get in order to fit the Spirit AND the ratchet set into it?I believe so. when I asked felinevet about it last night he said the set he has has a sheath that holds both the bits/ratchet and spirit.BrettAh good, you are already aware of it then. Thanks Bob! I am excited to try it out.All the reviews seem to point to it being a very handy toolBrett
Yeah, you want to make sure you get both the ratchet and the little extension thingy. When inserted into the ratchet it works great both with the bit inserted into it and the bit inserted into the end of te ratchet. Without the extension, it does not work as well in either configuration.
I want the extension!
Good call bdws, what would you tell the wife without the extension!
I bought one at countr knives it came to 15 dollars with shipping
Quote from: scrappy on April 15, 2008, 06:45:40 AMI want the extension!I was just thinking, if you are not stuck on getting "OEM" Vic extension, a $2-3 magnetic bit holder (for use in cordless drills) should do nicely...
