What is being carried today ?
colt 1911 · 30336 · 821630
Re: What is being carried today ?
Reply #15240 on: January 18, 2019, 07:33:14 PM
Great carry effjaybay  :tu: :like:
us Offline effjaybay
Reply #15241 on: January 18, 2019, 07:37:43 PM
Thanks Wspeed  :cheers:
Reply #15242 on: January 18, 2019, 09:03:17 PM
Reply #15243 on: January 18, 2019, 09:03:39 PM
BO SURGE!!! today :D
Reply #15244 on: January 18, 2019, 09:11:21 PM
Nice pic of the SURGE !!!! :D :cheers: :like:
Reply #15245 on: January 18, 2019, 09:48:12 PM
Thanks Ws  :hatsoff:
za Offline Max Stone
Reply #15246 on: January 18, 2019, 09:50:02 PM
ST300 today with a buckle showing another heavyweight.
How is the quality of that Heritage sheath ?
Good - I give it 4 out of 5. Only reason for the mark taken away is that they misaligned the loop on the back when it was stitched on. Stamped "PROUDLY MADE IN USA" on the back. Fits the ST well (does not catch the locking levers), and easy to deploy. I can recommend it  :tu:
Reply #15247 on: January 18, 2019, 10:17:11 PM
Great job and you should apply for the Hacker Badge  :tu:
Thanks   :hatsoff:- will do once the pocket clip is on!
So the Kick pocket clip arrived today and is proudly installed on my Rebar  :tu:
Not a straight drop-in...I had to cut a slot in the handle for the "anti-rotation" tab, enlarge the flat area around the pivot area to get a flush fit, and finally fabricate a washer from scratch to take up the space inside the clip's mounting hole, as normally this would fit over the rivet. But in this mod, the new torx screw replaces the rivet, so the clip's mounting hole effectively needs a resize to make it smaller.
My Rebar mod is now complete and I'm really happy with the result! Apart from the pocket clip, and if you look closely, the brass bushings on the locking lever pins, it looks 'stock' from the outside. However, open it and you discover a Wave+ head, diamond file, scissors and bit adapters, so quite a transformation.
As a newbie to this forum and not sure of the process, any chance I can apply for the Hacker Badge?  :salute:
* IMG_2131.jpg (Filesize: 77.75 KB)
* IMG_2132.jpg (Filesize: 78.39 KB)
* IMG_2133.jpg (Filesize: 74.49 KB)
* IMG_2134.jpg (Filesize: 131.79 KB)
« Last Edit: January 18, 2019, 10:24:50 PM by Max Stone »
us Online SteveC
Reply #15248 on: January 18, 2019, 10:25:04 PM
Great job Max, you absolutely can apply for the hacker badge   :cheers:
Here is how
https://forum.multitool.org/index.php/topic,59292.msg1084484.html#msg1084484
us Online SteveC
Reply #15249 on: January 18, 2019, 10:25:29 PM
us Online SteveC
Reply #15250 on: January 18, 2019, 10:25:57 PM
Mine today   :tu:
Reply #15251 on: January 18, 2019, 10:44:48 PM
Here is how
Thanks SteveC - Done  :hatsoff:
us Online SteveC
Reply #15252 on: January 18, 2019, 10:46:45 PM
Badge awarded  :cheers:   Congrats and well deserved  :tu:
Now you can go for the mod user badge   :pok:
Reply #15253 on: January 18, 2019, 10:57:54 PM
Hey - my first badge!  :ahhh
Will definitely go for the mod user badge, but it deserves a bit of a write-up.  :salute:
Reply #15254 on: January 18, 2019, 11:05:36 PM
Congratulations on your badge Max Stone  :cheers: :like:
Reply #15255 on: January 18, 2019, 11:50:53 PM
Thanks Steve :hatsoff: and great pic yourself :like:
Great mod, Max and congrats on the badge  :cheers: :like:
us Online SteveC
Reply #15256 on: January 19, 2019, 06:05:45 PM
Reply #15257 on: January 19, 2019, 06:07:26 PM
Cool pic Steve  :like: :tu:
Reply #15258 on: January 19, 2019, 06:46:43 PM
Nice duo, Steve :like:
Reply #15259 on: January 19, 2019, 09:01:25 PM
ST300 and SwissChamp today
Only Tools Matters
Reply #15260 on: January 19, 2019, 09:03:17 PM
Great combo Antti  :tu: :like:
us Online SteveC
Reply #15261 on: January 19, 2019, 09:04:34 PM
Thanks fellas and nice combo Antti !  :like: :tu:
Reply #15262 on: January 19, 2019, 09:20:58 PM
Thanks
Thanks
Only Tools Matters
Reply #15263 on: January 19, 2019, 09:31:48 PM
Cool mod, congrats to your first batch Max  :hatsoff:
Reply #15264 on: January 19, 2019, 09:33:29 PM
Reply #15265 on: January 19, 2019, 09:36:03 PM
ST300 and SwissChamp today (Image removed from quote.)
Only Tools Matters
Mighty combo Antti Lammi  :tu:
Reply #15266 on: January 19, 2019, 11:54:59 PM
Great combo, Antti :like:
us Online SteveC
Reply #15267 on: January 20, 2019, 12:24:43 AM
Thanks Matt !   :cheers:
us Online SteveC
Reply #15268 on: January 20, 2019, 06:43:47 PM
Reply #15269 on: January 20, 2019, 06:54:20 PM
Great carry Steve  :tu: :like:
