Damn you boss man, why did you have to do such a good sales job ? this morning i'd never even heard of them now i want one
The knife blade is bigger. It's still not as big as it could be, but it is the bigger blade taken from the PowerAssist. Also, the blade handle is a lot of wasted space on this one as it has the same lock mechanism as the PowerAssist, but it doesn't have the spring assisted blades, which means all the space reserved for the spring assist module is just open space on the BlackTip.Def
Quote from: Grant Lamontagne on May 21, 2013, 07:04:21 PMThe knife blade is bigger. It's still not as big as it could be, but it is the bigger blade taken from the PowerAssist. Also, the blade handle is a lot of wasted space on this one as it has the same lock mechanism as the PowerAssist, but it doesn't have the spring assisted blades, which means all the space reserved for the spring assist module is just open space on the BlackTip.DefI'd count that as a plus cause if it had the spring assist module it would be illegal to carry in most of Europe and a lot of other countries around the world too. Like this I can own one.
Quote from: enki_ck on May 21, 2013, 07:46:30 PMQuote from: Grant Lamontagne on May 21, 2013, 07:04:21 PMThe knife blade is bigger. It's still not as big as it could be, but it is the bigger blade taken from the PowerAssist. Also, the blade handle is a lot of wasted space on this one as it has the same lock mechanism as the PowerAssist, but it doesn't have the spring assisted blades, which means all the space reserved for the spring assist module is just open space on the BlackTip.DefI'd count that as a plus cause if it had the spring assist module it would be illegal to carry in most of Europe and a lot of other countries around the world too. Like this I can own one. Also the spring assist is kind of awkward to use anyhow. Its not my fav feature of the powerassist at all, but I still had to get one to fiddle with.
It is indeed, as is the Cable Dawg, but as neither of those fold up I wasn't considering them in the same category. DefSent from my MB860 using Tapatalk 2
no, you're right, i'm just being a smartass :pive a blacktip and its huge for this kind of toolthe replacable cutter are neat tho... neat neat neat
I think I have found a folding tool that out compounds SOG on the wire cutting front (Image removed from quote.)(Image removed from quote.)A Aussie made ,1943 WWII army issue Sunshine wire cutter.Good to hear the Blacktip's blades are not AO ,I have been meaning to ask that, should be legal in Oz too.
Quote from: MultiMat on May 24, 2013, 04:33:15 AMI think I have found a folding tool that out compounds SOG on the wire cutting front (Image removed from quote.)(Image removed from quote.)A Aussie made ,1943 WWII army issue Sunshine wire cutter.Good to hear the Blacktip's blades are not AO ,I have been meaning to ask that, should be legal in Oz too.Now that's some leverage Mat!¡! I'm sure they would slice through barbed wire like butter
Quote from: stealth007s on May 24, 2013, 05:49:30 AMQuote from: MultiMat on May 24, 2013, 04:33:15 AMI think I have found a folding tool that out compounds SOG on the wire cutting front (Image removed from quote.)(Image removed from quote.)A Aussie made ,1943 WWII army issue Sunshine wire cutter.Good to hear the Blacktip's blades are not AO ,I have been meaning to ask that, should be legal in Oz too.Now that's some leverage Mat!¡! I'm sure they would slice through barbed wire like butter Terry it is funny when I saw the auction photos there was no scale & I thought the tool was half it's actual size .The manufacture 'Sunshine' was once the biggest manufacturer in the southern hemisphere mainly making agricultural equipment, they closed down some time ago. During WWII they made pliers & wire cutters. I believe this is indeed the bared wire cutter . I tried it on the thickest piece of wire I had in the shed, a chunky old coat hanger, & initially I thought 'why hasn't the wire cut yet'?. I think it was just the amount of handle movement required to cut is quite large , ie the compound leverage, especially when compared to a SOG . I must ask a friend that has a small farm if I could try it out on some spare barbed wire . I think you are right , they should eat barbed wire
