Corneta machete Nr.66 by Weyersberg, Solingen
00 Offline kwakster
on: May 22, 2013, 07:05:12 PM
This vintage Corneta machete from the '50's or '60's of the previous century was made by Weyersberg in Solingen, Germany.
Later the brand was sold to South-America, i think to Imacasa.
The machete was completely unsharpened when i bought it, but when i saw it's tapered blade and felt the balance i just knew it had to have a good edge.
Reprofiling was done on the Tormek and refining to a slightly convex and razorsharp +/- 30 degrees inclusive edge on the grit 60 & 180 Rubber Wheels.
The chromed blade is quite flexible and the steel is both harder as well as more wear resistant than previous machetes i've sharpened.
One of these days i'm going to find out what it can do.
Specs:
Overall length: 21.3 inch (54,0 cm)
Blade length: 16.0 inch (40,7 cm)
Blade thickness: tapering from 2,25 mm before the handle to 1,25 mm just before the point.
Steel: chromed carbon steel
Handle material: Natural horn with brass rivets
Weight: 307 grams
Re: Corneta machete Nr.66 by Weyersberg, Solingen
Reply #1 on: May 22, 2013, 07:47:15 PM
Nice display piece you have there. :tu:
Reply #2 on: May 22, 2013, 10:04:38 PM
that looks excellent mate. :tu:
Reply #3 on: May 22, 2013, 10:50:10 PM
It looks almost too nice to use
Interesting to hear that the steel is good  :salute: (in the past I've always thought that a chromed blade was hiding rubbish steel  :think: )
ph Offline Goatlord666
Reply #4 on: May 23, 2013, 03:26:56 AM
didn't realize that it was carbon steel...such a beautiful piece. excellent scabbard too
Cheers,
Gabriel
"Balisongs Forever!!!"
pt Offline RamoN
Reply #5 on: May 23, 2013, 05:30:05 AM
Wow thats the shiniest and neat machete i ever seen :D So when are you planing to test it against some wood  :pok:
Here is the current corneta site in brazil http://www.corneta.com.br/en/index.php
Offline Dan Mai
  • New User
Reply #6 on: October 17, 2019, 07:48:22 PM
Buenas tardes... Existe aun esta empresa de machetes CORNETA SOLINGEN..?? Me interesa mucho los machetes
