I'd love to take a saw and chop open a faulty plier head to see whats going on in there.
Quote from: Syph007 on June 06, 2013, 07:35:23 PMI'd love to take a saw and chop open a faulty plier head to see whats going on in there. The assembly after that might be a bit tricky though.
Another QC fail on the latest Wave. The file and particularly the saw are now lying much deeper in the handles making them more difficult to get out. This is unacceptable for a new model. Apparently they have changed to a new press which has resulted in deeper handles. This should have been spotted and corrected before allowing to pass QC. I am thinking of cutting a small piece from a plastic clip and placing it inside the handle to prevent the saw going too deep, so I can easily get to the notch.The date codes are now on the side.
Quote from: hennypenny on June 08, 2013, 08:26:23 AMAnother QC fail on the latest Wave. The file and particularly the saw are now lying much deeper in the handles making them more difficult to get out. This is unacceptable for a new model. Apparently they have changed to a new press which has resulted in deeper handles. This should have been spotted and corrected before allowing to pass QC. I am thinking of cutting a small piece from a plastic clip and placing it inside the handle to prevent the saw going too deep, so I can easily get to the notch.The date codes are now on the side.Hmmmm deeper handles may mean the rebar head can sit on the chassis along with the scissors. *think*
Quote from: Metropolicity on June 08, 2013, 03:40:42 PMQuote from: hennypenny on June 08, 2013, 08:26:23 AMAnother QC fail on the latest Wave. The file and particularly the saw are now lying much deeper in the handles making them more difficult to get out. This is unacceptable for a new model. Apparently they have changed to a new press which has resulted in deeper handles. This should have been spotted and corrected before allowing to pass QC. I am thinking of cutting a small piece from a plastic clip and placing it inside the handle to prevent the saw going too deep, so I can easily get to the notch.The date codes are now on the side.Hmmmm deeper handles may mean the rebar head can sit on the chassis along with the scissors. *think*Love your thinking
I just got a new Rebar yesterday and it has none of the problems mentioned here, the pliers don't lock up like BigMatt's, the tools aren't loose and the little spring inside isn't loose. However, when closed the halves don't line up very well, they're about 1/8" off. Every single Juice I've owned, and I've owned about 5, have had the same problem with the halves not lining up when closed. I sent the first Juice back after another problem with it occurred and they sent me a replacement that didn't line up either, so since then I haven't bothered. Yea, it would be nice to see Vic QC come to Leatherman, or at least a step in that direction.That being said, I really like the Rebar.
For Juices, only the Kf4 has symmetrically thick halves; all other models have different thicknesses to the sides, which might make it appear not lined up.
Quote from: Sazabi on June 14, 2013, 02:41:03 PMFor Juices, only the Kf4 has symmetrically thick halves; all other models have different thicknesses to the sides, which might make it appear not lined up.I believe the xe6 is even too, but the corkscrew makes it feel uneven.
Quote from: Metropolicity on June 14, 2013, 03:25:53 PMQuote from: Sazabi on June 14, 2013, 02:41:03 PMFor Juices, only the Kf4 has symmetrically thick halves; all other models have different thicknesses to the sides, which might make it appear not lined up.I believe the xe6 is even too, but the corkscrew makes it feel uneven. ... I can't remember as it's been a while since I let my XE6 go, but the CS4 if definitely uneven, and I thought the file and serrated blade was the same thickness, which would mean the XE6 has the same offset, This is unless they compensated for it at the factory, in which case why not do it with them all?
Rise old thread! RISE!!Ok, my file won't lock in on my wave. On closer inspection, the bump on the outside of the liner lock is half worn off from about 2 days of use from when I first got the wave new. Not only that, but the small hole in the file that the ball fits into to keep it locked in is far to small to fit the ball, so my file will open up whenever my wave is moved fast enough. Now I'm assuming the design of the hole and the ball are intentionally like that, but i cannot see how that is supposed to work, and the ball was pretty much ground like it is now from when i opened the box. the pictures are taken at pretty much the same distance so it should give you an idea of how much smaller the hole is.
Just got a new Style CS, the nice little holes in the blade were missing. Not a real problem, but i liked those holes...(Image removed from quote.)
Quote from: bounding star on February 09, 2015, 10:33:53 AMJust got a new Style CS, the nice little holes in the blade were missing. Not a real problem, but i liked those holes...(Image removed from quote.)Could you please post a pic that shows the nail nick side of the blade.
