84mm scissor springs
stot · 4 · 1496
Offline stot
on: May 30, 2013, 06:30:47 AM
I picked up a Salesman in need of a new scissor spring. A seller on Ebay lists a "Medium" spring that is supposed to fit 74 and 84mm. Is this correct? The knife is early 80's and I assume it originally used the wishbone type spring. Can any one guide me to the correct replacement.
Swissarmy.com is a bit slow answering my request.
Thanks,
au Offline PTRSAK
Re: 84mm scissor springs
Reply #1 on: May 30, 2013, 07:50:30 AM
I used a "medium" spring in my 84mm scissors and it fits just fine.
It definitely is the 74mm size but it works perfectly.
Reply #2 on: May 30, 2013, 01:04:59 PM
With a bit of fitting and banding you can use a 91mm spring too.
Ignoring the old single leaf springs there are actually four sizes.  Small for 58mm, large for modern 91mm; but there are also specific springs for 74mm and a different size again for 84mm and old 91mm.  Most stores will only carry small and large as that is all they are ever likely to be asked for.
Offline stot
Reply #3 on: May 31, 2013, 10:23:16 PM
Thanks guys,
I remembered I had an Executive in a box my Swiss Army pen came in so I stole the spring and stuck in the Salesman. I wish it was flat on the end since the scissors don't have a groove for the spring to ride in but it should work OK. I replaced a spring in a 91mm a few weeks age in about 30 seconds. I was beginning to think I would destroy the spring on this before I succeeded. I wish I had ordered more than one new spring. I was a real pain!
