Custom scales on Wenger Ranger....
Sags · 6 · 2615
us Offline Sags
on: June 05, 2013, 10:53:43 PM
Just wondering if anyone here has done any custom scales on a Wenger Ranger.
I'm thinking about doing it, currently I'm brainstorming ideas on how to make the wrap-around (where Wengers wrap around the liner, vs Vics that sit on top).
I've done several sets of custom scales on Vics, but the wrap-around design of the Wenger presents a new challenge, I have a few ideas just wondering how others have done it.
us Offline ColoSwiss
Re: Custom scales on Wenger Ranger....
Reply #1 on: June 06, 2013, 12:35:18 AM
Hi Sags,
Welcome to the forum!
I have a couple of Wengers with custom handles, carbon fibre/G-10 and rosewood. Neither was done as a wrap-around, but simply flush with the liner. Both look good.
Reply #2 on: June 06, 2013, 12:41:55 AM
I've done it on the 85mm frame but not a 130mm Ranger size.
Here's a "How to" I did on making Wenger wrap around as you call them scales. I messed the paint job a bit but I like the scales on that one.
http://forum.multitool.org/index.php/topic,27696
I hope it can help you out on the bigger frame too. :salute:
au Offline PTRSAK
Reply #3 on: June 06, 2013, 02:06:18 AM
This Wenger Commander was dome with recessed or wrap around scales.
Method: Cut the recess before shaping the scales, trace around the side scales and then use Dremel and steady hand, work slowly, it's easier than putting material back on ::)
us Offline Sags
Reply #4 on: June 06, 2013, 06:42:41 AM
Thanks for the ideas and pictures.
I know I could do the recess out of one piece with a dremel, it's just difficult to be precise that way.  I was thinking about maybe doing each side in 2 pieces, using the scroll saw w/ fine spiral blade to cut out a perfect hole to match the liner, then adding that to a flat piece to make the recess.  That way the part that wraps around could also be a different kind of "highlight" material.
Although I usually work in wood, I was also thinking that I want to do something more colorful this time... was looking at this stuff
http://www.texasknife.com/vcom/product_info.php?cPath=587_604_615&products_id=1489
My worry with it is that being polyester it will be to slippery after it's polished especially when wet, or with sweaty palms.
au Offline PTRSAK
Reply #5 on: June 06, 2013, 08:00:59 AM
I've used something like that,
Toffee-Chocolate Swirl...   resin
not really any more slippery than any other polished plastic.
