keep us updated. I'd buy a book.
My plan is to use any name currently in use to refer to the model currently in production. So, if I refer to a "Handyman", that means the current incarnation of that model (Ranger w/ pliers), and not the older version (Ranger w/ fish scaler). So what to call the older version? - Handyman Classic- Handyman Original- Something elseAny thoughts are appreciated. Thanks!
Few other humble suggestions for avoiding repeated-name confusion:1) Categories everything under different era
2) 2 Categories: Current production vs Ceased production
Quote from: comis on September 03, 2013, 08:21:32 AMFew other humble suggestions for avoiding repeated-name confusion:1) Categories everything under different eraI have a two level Periodization (eras and periods) that I developed years ago that will be a central part of the books. A couple of the other collectors here have seen it, but I never posted explicitly about it. The chapter on this periodization system I developed is actually the first one I'm working one; maybe I post a draft version of the chapter later this week if anyone is interested. Quote from: comis on September 03, 2013, 08:21:32 AM2) 2 Categories: Current production vs Ceased productionThis doesn't work very well because many knives can be out of production but later remade (e.g. The Yeoman, currently revived by SwissBianco).As for everything else, well I have a pretty detailed outline of the book already worked up and I'm going to start working from there. I'll put it this way - I want to make the book that I, as a fairly serious collector, always wished had existed.
...As for everything else, well I have a pretty detailed outline of the book already worked up and I'm going to start working from there. I'll put it this way - I want to make the book that I, as a fairly serious collector, always wished had existed.
Quote from: jazzbass on September 04, 2013, 08:35:34 AM I'll put it this way - I want to make the book that I, as a fairly serious collector, always wished had existed.Perfect approach IMHO Best of luck with it
Thought I'd post an update on the book. It is now books, not book. Originally my idea was to write about both simultaneously. I figured that yes, there are some minor difference in tool changes of the years (e.g. 84mm knives get 2.0mm blades at least 10 yrs before 91mm ones do), but the vast majority of the changes happened simultaneously and could be documented as such. Well, as I started organizing my research I've found there are a lot more differences than I originally thought. Trying to write about both product lines in the same chapter ends up being confusing, and if I break them out into their own separate sets of chapters, it essentially becomes two books. So that's what I've decided to do - write an 84mm and a 91mm book following the same basic format. I also realized while compiling a list of all known models of knives that there's a hell of a job ahead of me. I documented 48 different 84mm models and 125 different 91mm models, including all special run models that I know of. Good news from Ibach - Victorinox has given me permission to use their trademarks in the book, which is a pretty big relief. I'm not sure what the laws are regarding using a company's trademarks in a written work (with pictures) - can you do it without permission under fair use? No clue, but unsurprisingly Victorinox is being very helpful and supportive of this effort so it's not something I have to worry about. They really are a great company. Finally - I'd like some opinions. In outlining the section on the different knife models I decided that for ease of reference I want to have a unique name for each different model of knife. The plan is to list all "aliases" under the name (e.g. The Artisan, aka Craftsman), but each model should get it's own "reference" name. The problem is Victorinox has recycled a lot of names and many knives don't have unique names. Three in particular I'm thinking of are the Angler, Craftsman, and Handyman. These are all names that refer to current production knives. However, pre-1987, these names were used on different models. My plan is to use any name currently in use to refer to the model currently in production. So, if I refer to a "Handyman", that means the current incarnation of that model (Ranger w/ pliers), and not the older version (Ranger w/ fish scaler). So what to call the older version? - Handyman Classic- Handyman Original- Something elseAny thoughts are appreciated. Thanks!
And while we're wating for the book (I would personally happily buy an electronic version, but I'd probably not anything coffee table style from dead trees), we really appreciate they way you're sharing your research materials in different threads on the forum.
I'll go on record now and say I'll be buying one when they come out.
