Tell me about sharpening axe
jzmtl · 15 · 15824
ca Offline jzmtl
on: May 01, 2008, 04:55:27 AM
I bought a hatchet from local hardware store a while ago, the edge on it is about 1 mm thick and doesn't cut anything.
I used angle grinder with sanding disk to thin out the head to about 15° per side, then sharpened on sharpmaker at 20° per side. Below is a pic of what the edge looks like. I know it's not symmetrical, but that's the best I can do with hand held angle grinder, and holding the hatched on a stool with my foot.  :P
So did I do this right? Did I make it too thin or something or messed up the geometry?
Re: Tell me about sharpening axe
Reply #1 on: May 01, 2008, 10:20:44 AM
Looks ok to me as it's only a little bit out :), once you've used it a few time and resharpened it, it'll true it's self up anyway :)
us Offline NutSAK
Reply #2 on: May 01, 2008, 01:31:34 PM
I'd say you've certainly improved the edge.  It wasn't symmetrical to begin with, so it's probably best that you didn't immediately remove enough metal to true it up the first time.
- Terry
ca Offline jzmtl
Reply #3 on: June 22, 2008, 08:22:22 AM
Was sharpening the fiskars hatchet I just got. The secondary bevel on it is 30°, since it's almost a centimeter wide and teflon coated, it's pretty hard to sharpen at that angle so I went to 40° and followed by a little sandpaper on mousepad. But the instruction from fiskars does say sharpen at 30°, consider they've been making axe for hundreds of years I'd imagine they know what they are talking about. So did I ruin the geometry of the axe by increase the edge angle?
Offline Anthony
  • Improvise.
Reply #4 on: June 22, 2008, 05:00:55 PM
Go chop something and find out! :D
The edge doesn't have to be as delicate as a SAK or other small knife...and axe is made for heavy use...if it pops branches off a downed tree with one quick wrist snap I'd say it's sharp.
Offline Tarrodemierda
  • Smells like tar and smoke.
Reply #5 on: June 22, 2008, 05:02:44 PM
to me its teh only good way for axes and many other big blades.
ca Offline jzmtl
Reply #6 on: June 22, 2008, 08:15:47 PM
Heh I wish, living in the city I don't really have the luxury of go out and chopping something, only test I can do it cutting papers.  :cry:
us Offline Mike
  • Shop smart, shop S-Mart.
Reply #7 on: July 05, 2008, 08:37:31 PM
I use a file to take down the shoulder a little bit, then use a Lanksy Puck to finish it off. I also try to keep the bevel even on both sides of the blade. Since I normally only split wood with my axes, I think thinning down the shoulders help. However, I do not thin the edge down nearly as much as my knives. For my splitting axes I want a good amount of material behind the edge.  Now, if I was actually chopping wood I would probably thin the edge down a little more, but not overly so.
Mike
« Last Edit: July 06, 2008, 09:20:04 PM by mike »
Reply #8 on: July 06, 2008, 04:40:05 AM
I am not that much of an axe user but I find that a good file some time and a good eye are all it takes to have a good edge.  I use a file on my chisels as well the mason chisels don't get as sharp of an edge but I can make my wood chisels razor sharp.  Angle grinder sometimes can get a little agressive for me I occasionally use one when edge is bad ex. like the new axe you got then mantain it with a good mill file :)
us Offline WhichDawg
Reply #9 on: July 07, 2008, 12:16:21 PM
yeah I've heard them pucks are really nice for axes, I gotta get me one.
ca Offline jzmtl
Reply #10 on: July 07, 2008, 03:11:21 PM
You need to use sand disk not grinding stone, I use 120 grit disk and it gives a very smooth finish.
ar Offline mcniac
  • Don't Panic!
Reply #11 on: August 20, 2008, 02:59:39 AM
i like axes, and i like em sharp, this is the way i sharpened the last axe i bought, it is a chinese copy of a bahco, kinda cheap but has been working good since 2 or 3 months ago.
- first use a file to thin out the edge
- then go with a coarse stone (both file and stone freehand, i mean no jigs or anything like that)
- when the axe is getting closer to what i want i use some sandpaper over a mouse pad to give a kinda convex edge, and well polished
this kind of sharpening gives me an axe that will chop good and also can be used in woodworking
here you can see a pic of the axe along with other pieces of my kit
and in case you want the bigger pic (wallpaper size) http://picasaweb.google.com/esteban.soler/Wallpaper/photo#5225938044979852418
Cheers
Esteban
Offline crls1
  • I do Exist!!!!
Reply #12 on: August 20, 2008, 03:33:11 AM
This is a good axe sharpening tutotial over BushcraftUK. Very informative and lots of pictures
Carlos
http://www.bushcraftuk.com/forum/showthread.php?t=22814
00 Offline Freudian Frog
Reply #13 on: August 20, 2008, 03:59:37 AM
I go for a very lazy convex edge. XD
Got those frog legs.
Reply #14 on: August 20, 2008, 09:43:37 AM
Look's like a good set up Esteban :)
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
