So when did they stop putting their name on the blades ?
Dunc · 18 · 3970
As you all know by now I have a new MP600 I presume its very recent manufacture as it came direct from Gerber . There is no Gerber name on any of the blades, infact no writing at all which I find a little strange .
Another thing is on the tape measure the last line near the 8cm isnt straight , its no big deal but its about 1 mil difference from top to bottom . Not sure if its clear in the photo . Do you think its a one off or do you think they stamped out thousands .
Dunc
gb Offline Roadie
  • Hello...is this thing on?
All my blades have Gerber USA stamped on them, I think the ruler is out on all of them though as my two MP600's are both off :(
Thanks for looking for me  :D  So the ruler thing is cleared up . How old are your MP600's ?
Dunc
gb Offline Roadie
Dunc
Yes...... i have no idea, and i don't think there's any way of telling.
Dunc
Not as far as I know  :think: There must be some other 600 owners along soon .
Dunc
Some one put a call out to Bob then :D
Offline Leatherman123
All of my Gerber tools have the Gerber USA stamped onto the knife. The ones I checked are older ones though. I will check my other Gerber's later. I checked my 400 and 600 because they are at my computer table because I like to play with the pliers!
B
Offline I'm Still Bison
I took a look at mine,it's about 3 years old,and the mark is off on mine as well. I wish I could give you a reasonable answer why your blade isn't marked,but all I could do is speculate,is that possibly is was pulled from a spares or blem bin.
I
Mine with the Wharnecliffe blade on the newest-version MP600's doesn't seem to have any Gerber logo on it either. I can't tell exactly what type of knife blade you have there Dunc? I do notice your nail notch goes clear thru though, which isn't always the case.
I never noticed that distorted 8mm marking before. It's on all of mine too. Notice how the 8 is near where the handle necks down to fit inside the opposite handle? That bend is a tough feature for a metal stamping to make. The metal has to sssttrrrretch. (try to imagine what the handle would look like if you could unfold it and lay it flat. See? It can't be done without stretching)
My guess is they stamped the ruler when the metal was flat, then folded it into a channel shape, whereupon the metal distorted and messed up the 8 character.
(just a theory of course) :-\
Did I understand you right that you have one that has no blade markings ?
Thanks
Dunc
Re: So when did they stop putting their name on the blades ?
Reply #10 on: May 03, 2008, 08:36:54 AM
I think your theory could be right , sounds good to me .
  Heres a pic of the blades
Dunc
Reply #11 on: May 03, 2008, 03:34:19 PM
No,my blade is marked,I was speculating that maybe your blade may have come from either a blem bin,or pulled from a bin before markings were stamped.
I
Reply #12 on: May 03, 2008, 03:37:52 PM
My Gerver 700/800 both have blade markings also..
B
Reply #13 on: May 03, 2008, 08:13:34 PM
Neither the plain edge or the serrated have markings  ??? But both are faultless ( that I can see ) . If it had come from a bins bin you would have thought the stamp would have already been put on before this stage  :think:
    Maybe because its a warrenty replacement its made up from rejected parts ? I doubt it though as theres nothing wrong with it .
Dunc
Reply #14 on: May 05, 2008, 05:58:00 PM
Ok I emailed Gerber and they very quickly replied with this ........
Quote
Hi Duncan,
Thank you for contacting Gerber Blades.  Probably within the last 5-6 years the process of stamping our blades has ceased.  The purpose was cost efficiency and expediency as the demand for the product(s) grew.
Sincerely,
Donda Burnett
Consumer Affairs
So the ones with Gerber on the blade are older then five or six years . I guess thats why mine has cut out instead of nail nicks .
If anyone can Duncan Can  ;)
Dunc
gb Offline Roadie
Reply #15 on: May 05, 2008, 06:03:00 PM
Quote
Hi Duncan,
Sincerely,
Donda Burnett
Consumer Affairs
Dunc
See i knew you'd be able to drag it out of them :D Interesting to know though, means all my tools are older than i thought :)
Reply #16 on: May 05, 2008, 07:22:57 PM
Good one mate, thats a pretty quick response from gerber too :)
Reply #17 on: May 06, 2008, 03:00:40 AM
Thanks for inquiring Dunc, and thank you Gerber for the quick reply.  :)
