JA,s OHT challenge.
JAfromMn · 671 · 55672
us Offline JAfromMn
  • Stranger in a Strange Land
Re: JA,s OHT challenge.
Reply #240 on: September 19, 2013, 01:36:16 AM
The oht had a pretty easy day today.
I used it to clip a few wires and the serrated blade to cut some drain house but I didn't get any pics its to dark under houses to get a good one.
I did get a pic of putting a plate back on my work truck.
and here's the requested pic for  50ft-trad
surprisingly the oht's saw is shorter than a 84mm wengers by a centimeter or 2
the Vic saw is quite a bit longer.
edit
saw thoughts
I would have never thought the oht's saw was a little shorter than a standard wenger
It's never felt like it was to short when I've used it.
the handle is comfortable to use / easy to grip and hold when sawing.
I'd prefer a replaceable blade but the saw it has works and seems to stay sharp .
one hand opening kicks ass :tu:
« Last Edit: September 19, 2013, 02:53:33 AM by JAfromMn »
Defend the Hive!!!
us Offline Monrogue
  • Wooooo!
Reply #241 on: September 19, 2013, 03:34:37 AM
Nice saw comparison pic Joel :tu:  Keep up the good work with this thread my man.
K-Tibbs
Reply #242 on: September 19, 2013, 12:58:33 PM
One of my (and other people's) criticisms has fell on the shortness of the blade and saw, although in truth I have personally found the short blade on the MP700 to be perfectly adequate for many (urban) chores. We can see the length is rather stubby compared to the body of the tool, but is there any chance of comparison pics to the length of the blade & saw on a 91mm Vic and 85mm Wenger please anyone?
The Blades might be a little short, but they work rather well and sometimes you just need a small blade to get into tight places. As for the saw,  it is a beast. I tend carry a regular blade with my multi and it seens like the LOHT was made to compliment a dedicated knife.
sent from my mobile
Reply #243 on: September 19, 2013, 01:43:00 PM
<snip>
edit
saw thoughts
Thanks for that JA  :tu:
That saw is actually even shorter than I though  :o :o BUT at least it's outboard on this tool, which means that more of the blade is usable (unlike the Rebar / ST300 etc)
sent from my mobile
But it's tiny!  >:D All this praise for such a small saw  :P It must be like the vicious bunny in The Holy Grail  :D
Many thanks for the pics and comments guys, you've convinced me it's really not for me (thank you :D) but I'm very glad it's working so well for you two  :tu: :salute:
ca Offline CanadianLMfan
  • All Lurkers Please Join :D
Reply #244 on: September 19, 2013, 01:45:00 PM
Sorry I'm so slow
pizza for me/Mrs.ja and gravy train for the doggies
the can opener works well I got the can open in about 20 seconds
it was smooth cutting and it was fun one hand open my can opener  8)
more important to me the tool/coating held up to opening the can  :multi:
sorry for the crapy pics
Finally!
Leatherman
us Offline JAfromMn
Reply #245 on: September 19, 2013, 07:51:00 PM
I just used the oht to pry open 5 locked mailboxes that where missing keys
the flat driver worked to get them open with no damage to the tool.
the only other tool I've used to pry them open was the crate opener on a swisstool.
this is one tough leatherman.
I used a lot of force /border line abuse/
ive bent cheap screwdrivers trying to do the same thing.
« Last Edit: September 19, 2013, 07:53:03 PM by JAfromMn »
Defend the Hive!!!
us Offline sawman
  • You're amongst friends.
Reply #246 on: September 19, 2013, 08:58:33 PM
SAW
hr Offline styx
Reply #247 on: September 19, 2013, 09:08:51 PM
Shouldn't all Leatherman's be tough?
us Offline JAfromMn
Reply #248 on: September 19, 2013, 09:51:36 PM
very true they should be.
some though are not
but I do think as long as i use the right tool for the right job i shouldn't break one. Pushing a tool over its limitations leads to broken tools.
Defend the Hive!!!
Reply #249 on: September 19, 2013, 11:08:46 PM
Leatherman flat drivers are awesome! Well, most of them.
Leatherman
us Offline JAfromMn
Reply #250 on: September 20, 2013, 04:48:58 AM
Todays' oht work
I was putting in ac again on a few homes today.
here's what I used the oht for.
the first time I used it this morning was getting a screw out that I couldn't get at with the drill/driver
I needed to get a pic of this task I usually do under houses.
I don't try bring my phone with me anymore.
I'm on my 3rd Nokia this year already  :o
cutting the clear rubber hose I use for drainage
 tightening a plastic cap on copper tubing for ac refrigerant. I put these little caps on and take them off each line I install. Two lines per ac unit. one feed one return.
I also usually do this under the home but I'm trying to get a decent pic of each tool in use. I'm a nerd  >:D
 pocket dump
the oht does all the work. I carry the rest because I'd miss it.
ok I need the light too lol
« Last Edit: September 20, 2013, 07:29:34 AM by JAfromMn »
Defend the Hive!!!
hr Offline styx
Reply #251 on: September 20, 2013, 10:50:43 AM
Has the length of the Phillips driver hindered you in use so far? Any changes you wish for except the obvious one - put a file on it.
Reply #252 on: September 20, 2013, 01:40:16 PM
That was a heavy day!
Leatherman
us Offline sir_mike
  • It is what it isn't.
Reply #253 on: September 20, 2013, 05:41:38 PM
Hey Joel,
Just wondering if a bit adapter that was made for the Juice line as well as others would fit on the philips driver so you can use a vairiety of bits!
If so, that would be great! :D
Reply #254 on: September 20, 2013, 06:57:49 PM
I was wondering that myself, but I dont have the bit adapter to try.
sent from my mobile
us Offline JAfromMn
Reply #255 on: September 20, 2013, 07:26:13 PM
Hey Joel,
sorry mike I don't have the bit adaptor.
I hope it does.
Defend the Hive!!!
us Offline JAfromMn
Reply #256 on: September 20, 2013, 07:43:31 PM
well styx
I haven't been hindered by the Phillips driver its plenty long. The flat driver on the other hand is to short.
hmm changes besides a file. Hmm
ditch the can opener for a awl would be my first suggestion.
 I'd like to see a scissor offered by putting in a combo edge blade and losing the serrated blade.
leatherman should really make a civilian oht. This is a good tool. It just needs a little work to be a excellent one.
« Last Edit: September 20, 2013, 07:58:56 PM by JAfromMn »
Defend the Hive!!!
hr Offline styx
Reply #257 on: September 20, 2013, 08:26:52 PM
Then they should definitely take your suggestions into account as I'm sure a lot of people would agree with you on at least some points
us Offline sir_mike
Reply #258 on: September 20, 2013, 09:18:10 PM
Joel,
I wasnt really asking if you had the bit extender for the juice line, just wondered if one would fit that OHT so you could adapt other bits and in the case wihere the flat driver is too small for the job. :D
I kinda thru that out there to see if anyone would comment if they had both or if they know if would fit or not fit!  Anyone?
Curious, ya know!  It would be a big plus if it does!  :tu:
well styx
us Offline JAfromMn
Reply #259 on: September 20, 2013, 09:39:15 PM
I bought the file I need today for the oht.
I hope to get it fitted today or Monday.
Defend the Hive!!!
us Offline Monrogue
  • Wooooo!
Reply #260 on: September 20, 2013, 10:29:48 PM
Nice Joel, I hope the file works out for you :tu:
K-Tibbs
us Offline sir_mike
Reply #261 on: September 20, 2013, 11:13:20 PM
I know this doesnt need to be said but "we need pics when finished".  LOL
Reply #262 on: September 20, 2013, 11:22:46 PM
Pictures?
Leatherman
us Offline JAfromMn
Reply #263 on: September 21, 2013, 01:28:52 AM
I didn't get to the file today.
Il get it done Monday.
today I used the oht to cut a lot of wire and to tighten a value missing it's handle.. The one hand opening was very useful when working in tight spots.
photobucket is having issues so sorry no pics for now
edit photobucket is still down.
« Last Edit: September 21, 2013, 03:27:30 AM by JAfromMn »
Defend the Hive!!!
bmstrong
  • Guest
Reply #264 on: September 21, 2013, 03:34:58 AM
I'm more interested in pics of the tear down and reassembly of the OHT itself. How does it come apart, what it looks like apart and how easy it is to put back together.
I'm also happy you got your file.
us Offline JAfromMn
Reply #265 on: September 21, 2013, 03:41:21 AM
thanks bmstrong
I'm not going disassembled my oht. Sorry.
I know metro has. He said that it comes Apart easy.
I'm going to try find his old pics.
I know that I have seen them.
« Last Edit: September 21, 2013, 03:43:25 AM by JAfromMn »
Defend the Hive!!!
us Offline JAfromMn
Reply #266 on: September 21, 2013, 03:53:10 AM
Defend the Hive!!!
us Offline JAfromMn
Reply #267 on: September 21, 2013, 05:05:04 AM
 oht wire cutting
chomp chomp chomp  :multi:
Defend the Hive!!!
us Offline Monrogue
  • Wooooo!
Reply #268 on: September 21, 2013, 05:22:47 AM
oht wire cutting
Ha, love this pic :tu:.  Those pliers really do look larger, especially when you consider the pivot is still housed inside the handles.
K-Tibbs
fi Offline AlephZero
  • Smurf smash!
Reply #269 on: September 21, 2013, 11:56:37 AM
Nice pics :tu:
As I said before, those pliers are meant to devour their prey :D
I also notice that the OHT is gathering some beausage on it's way... I like tools that look like they're used a lot :)
"Hoarder of weirdness,
Always posting random things,
I'm AlephZero" :ninja:
