The actual contents of the pouch , less small parts . The larger screwdriver is a Milwaukee 11 in 1 , the smaller is a Klien 6 in 1 . This set up gives me #1-3 phillips , Robertson and flat + 1/4", 5/16", and 3/8" nut driving capacity . I have a back pocket pouch called a "arse protector " , which I use for utility knives , Linesman's pliers , and waterpump type pliers .
The compact level is a Stabila , it's magnetized , and very accurate if used properly . The pouch will also fit the Klien 10 in 1 , or 11 in 1 driver .
Chris
