SAK mod advice
wales Offline magentus
  • mmmmm SAKrelicious
SAK mod advice
on: September 05, 2013, 08:32:48 PM
I've been playing around with my Explorer since seeing a great mod (which I can't find now) and I'm seeking some advice;
I've added a bit adapter to the in-line Phillips and while it fits quite well, there is movement so I want to stabilise it as much as I can.
Any tips?
Here is a pic;
If I can get this to work I won't need a CT41 anymore!
Cheers
Re: SAK mod advice
Reply #1 on: September 05, 2013, 11:55:37 PM
Looks good...I done the opposite,done an adopter for the cap lifter.
Took a quarter inch socket,epoxy putty,and a liberal amount of Vaseline...oh no,here we go again :facepalm:
Re: SAK mod advice
Reply #2 on: September 06, 2013, 01:24:22 AM
Lmao! Yes you did.
sent from my mobile
us Offline ironraven
Re: SAK mod advice
Reply #3 on: September 06, 2013, 03:22:57 AM
Kirk, how is your origional holding up?
Re: SAK mod advice
Reply #4 on: September 06, 2013, 10:22:37 AM
Pretty well...might be worth asking 50ft-trad too,he has the first one I done :D
The key is to use something like Prattleys,which is pretty much bullet proof
Re: SAK mod advice
Reply #5 on: September 06, 2013, 05:07:00 PM
Cheers Kirk - I remember your mod and liked it very much. Do you have the link for it please?
 I don't have the tools to modify the bottle opener at the moment, and I guess the problem with using the phillips is that the head is wider than the neck so unless I fit a padded collar into the adapter there will always be a certain amount of movement. I'm not concerned with a perfect fit, just to improve on the current situation.
What is Prattleys?
Re: SAK mod advice
Reply #6 on: September 06, 2013, 08:49:37 PM
UPDATE - I have made a very simple plastic collar to line the adapter and it works perfectly. Pics to follow..........
gb Offline Cupboard
Re: SAK mod advice
Reply #7 on: September 06, 2013, 10:41:55 PM
I think they're referring to chemical metal/metal epoxy, like J B Weld and others.
Re: SAK mod advice
Reply #8 on: September 06, 2013, 11:08:54 PM
What is Prattleys?
http://forum.multitool.org/index.php/topic,30539.msg514334.html#msg514334
There's the link
Prattleys is a super strong 2 part epoxy...might be having brain slip and went for the South African brand name :oops:
