Surge or OHT
If the tti is too heavy for you, have a look at the Juice-series. The S2 is a good option if you're okay with it's limited toolset.Also take a look at the Gerber Balance. Loved by quite a lot of people here on the forum, it has about the same toolset of the Juice S2, but in a very different form.I'm not sure what you don't like of the Skeletool's blade, personally, I like it a lot, though I'd prefer the CX's one.
Now we're talking modding, you could also try the 'slim charge'. I think Metropolicity once made one, took off the saw and file "layer" leaving you with two knife-blades.
From what you have said in the OP you want:Outside opening bladegood steel pocket clip (?)lightweightWith all that in mind I'd suggest..............give me a sec.......nope I've got nothing. It's the high grade steel that's a real problem, basically the LM Charge is just about the only game in town if that's a must. A few I'd suggest you look at are the LM Wingman, Sidekick, Juice S2 and the Gerber Octane. But I STRONGLY suggest you go and have a physical look and play with them in a store, all of these tools have their fair share of fans and detractors, enough that I couldn't suggest them in good faith without mentioning it.Best of luck.
Quote from: Gareth on September 17, 2013, 06:50:05 PMFrom what you have said in the OP you want:Outside opening bladegood steel pocket clip (?)lightweightWith all that in mind I'd suggest....... .......give me a sec.......nope I've got nothing. It's the high grade steel that's a real problem, basically the LM Charge is just about the only game in town if that's a must. A few I'd suggest you look at are the LM Wingman, Sidekick, Juice S2 and the Gerber Octane. But I STRONGLY suggest you go and have a physical look and play with them in a store, all of these tools have their fair share of fans and detractors, enough that I couldn't suggest them in good faith without mentioning it.Best of luck. The Skeletool CX meets all those requirements. The 154CM steel that Leatherman uses for their blades is excellent. It may not have quite the same edge retention as S30V, but it's easier to sharpen. gdc -- you mentioned that you didn't like the Skeletool's blade. Are you referring to the combo edge blade made of 420HC steel on the "regular" version of the Skeletool? Or was there something you didn't like about the 154CM plain edge blade on the CX version?I love my Skeletool CX, in case it wasn't clear.
Quote from: Shotgundoug13 on September 17, 2013, 04:16:45 PMSurge or OHT (seeing as the OP finds a TTi too heavy).If you can live without outside opening tools and premium steel blade maybe a LM PST (or PST II if you want scissors), then maybe go the modding/swapping route to get exactly the tools you want.
i guess the real dilemma seems to be do you NEED pliers or blade? it sounds like blade is more important so the skele cx is a great balance of 154cm blade and a good set of pliers plus the bit. i have the regular ss skele and love it, i also just got a paratool and because size wise its very near the skele i love it too. skele has more carry options vs paratool and you mention mountain bike so you can always use the carabnier to attach it to your pack. ive always wondered why not just get a great main blade for those who demand high end steels and a simple yet effective MT for everything else. light main blade option seems easier then pair it with a juice. how about a spyderco native CPM s30v at under 3oz and a LM juice s2 both nearly the same weight as the paratool or skeletool?
I think the manufacturers are missing the potential of bladeless multitools in an ever confusing world of changing regulation. It also gives potential for pairing with blade of choice, of which there are thousands of variations on the market
Quote from: 50ft-trad on September 18, 2013, 10:25:17 AMI think the manufacturers are missing the potential of bladeless multitools in an ever confusing world of changing regulation. It also gives potential for pairing with blade of choice, of which there are thousands of variations on the market The only mainstream manufacturer that makes it easy for the less-skilled and/or less well-equipped would-be modder is SOG (including Paladin). They make a wide variety of components that can be swapped (without needing special tools) to suit most people (including bladeless MTs).
Quote from: Gareth on September 17, 2013, 06:50:05 PMFrom what you have said in the OP you want:Outside opening bladegood steel pocket clip (?)lightweightWith all that in mind I'd suggest..............give me a sec.......nope I've got nothing. It's the high grade steel that's a real problem, basically the LM Charge is just about the only game in town if that's a must. A few I'd suggest you look at are the LM Wingman, Sidekick, Juice S2 and the Gerber Octane. But I STRONGLY suggest you go and have a physical look and play with them in a store, all of these tools have their fair share of fans and detractors, enough that I couldn't suggest them in good faith without mentioning it.Best of luck. The Skeletool CX meets all those requirements. The 154CM steel that Leatherman uses for their blades is excellent. It may not have quite the same edge retention as S30V, but it's easier to sharpen. gdc -- you mentioned that you didn't like the Skeletool's blade. Are you referring to the combo edge blade made of 420HC steel on the "regular" version of the Skeletool? Or was there something you didn't like about the 154CM plain edge blade on the CX version?I love my Skeletool CX, in case it wasn't clear.
You're quite right of course Breezy, but as the PO said they'd tried the Skele and didn't like it I suppose I'd discounted the CX in my mind. Good catch mate.
Quote from: Aloha007 on September 18, 2013, 03:18:54 AMi guess the real dilemma seems to be do you NEED pliers or blade? it sounds like blade is more important so the skele cx is a great balance of 154cm blade and a good set of pliers plus the bit. i have the regular ss skele and love it, i also just got a paratool and because size wise its very near the skele i love it too. skele has more carry options vs paratool and you mention mountain bike so you can always use the carabnier to attach it to your pack. ive always wondered why not just get a great main blade for those who demand high end steels and a simple yet effective MT for everything else. light main blade option seems easier then pair it with a juice. how about a spyderco native CPM s30v at under 3oz and a LM juice s2 both nearly the same weight as the paratool or skeletool? the Skeletool only weighs 5 oz., and the Juice S2 weighs in at 4.4 oz. you're going to have a hard time finding a knife/tool pairing that weighs less than the Skele, unless you go to a keychain-size MT and/or a much smaller knife.
Quote from: Breezy12 on September 18, 2013, 06:41:54 PMQuote from: Aloha007 on September 18, 2013, 03:18:54 AMi guess the real dilemma seems to be do you NEED pliers or blade? it sounds like blade is more important so the skele cx is a great balance of 154cm blade and a good set of pliers plus the bit. i have the regular ss skele and love it, i also just got a paratool and because size wise its very near the skele i love it too. skele has more carry options vs paratool and you mention mountain bike so you can always use the carabnier to attach it to your pack. ive always wondered why not just get a great main blade for those who demand high end steels and a simple yet effective MT for everything else. light main blade option seems easier then pair it with a juice. how about a spyderco native CPM s30v at under 3oz and a LM juice s2 both nearly the same weight as the paratool or skeletool? the Skeletool only weighs 5 oz., and the Juice S2 weighs in at 4.4 oz. you're going to have a hard time finding a knife/tool pairing that weighs less than the Skele, unless you go to a keychain-size MT and/or a much smaller knife.my thinking was along the lines of the OP not liking the Skele and i figured that included the CX too. at 4.4oz for the Juice S2 and 2.65oz for the FRN Spyderco Native, OP would have needs met for "nearly" same weight as a Skele. i too feel Skele CX is best choice as i mentioned but again OP didn't care for it. just my thoughts.
I must admit I quite like the blade on the Skele .... it's the rest of the tool I can't stand
Quote from: 50ft-trad on September 19, 2013, 09:43:00 AMI must admit I quite like the blade on the Skele .... it's the rest of the tool I can't stand Too bad it's serrated on the normal one...
Quote from: CanadianLMfan on September 19, 2013, 01:51:47 PMQuote from: 50ft-trad on September 19, 2013, 09:43:00 AMI must admit I quite like the blade on the Skele .... it's the rest of the tool I can't stand Too bad it's serrated on the normal one...I can put up with that a lot better than the pliers and driver
