My MUT, with scissors
us Offline JAfromMn
  • Stranger in a Strange Land
Re: My MUT, with scissors
Reply #30 on: February 11, 2014, 01:56:55 AM
Bummer.
proof positive that Vic scissors are made of very hard steel  :facepalm:
Defend the Hive!!!
Reply #31 on: February 11, 2014, 01:22:11 PM
 Those are wire cutters, not heavy metal breaks.
that's us mobile
ca Offline derekmac
  • Little to the right...
Reply #32 on: February 11, 2014, 02:35:09 PM
Yeah, you'd be hard pressed to cut those using dedicated cutters.  Cutting the scissors is beyond the capability of MTs, IMHO.
se Offline Mr Biriyani
Reply #33 on: February 11, 2014, 04:20:42 PM
Great idea. Awesome to have separate scissors.
us Offline tommywp
Reply #34 on: January 23, 2015, 06:45:03 PM
Question for Derekmac or any others who have lived with this mod for a while...how has it worked out long term? Have you found that the scissors slide front-to-back when using the MUT (particularly when hammering)?  Real close to pulling the trigger on a MUT and hearing that the scissors have worked out long term may be the final straw.  Thanks.
il Offline dan.mandiel
  • i need a surge :cry:
Reply #35 on: January 23, 2015, 08:11:04 PM
I really dig the mut but i lack scissors really bad. Scissors is like the second most ofter used tool for me.
- Ok sir, we've found this good multitool without scissors-
-scissors.
- but sir, we figured it might not have scissors but it does have almost everything you need for a good price! -
- scissors.
- but sir..-
- sci. ssors.
00 Offline screwloose
Reply #36 on: January 23, 2015, 08:21:18 PM
bwah,  to be honest, i put mine in a draw and i use my victorinox again....
"if you haven't got a screw loose somewhere, you are probably wound too tight"
us Offline JAfromMn
Reply #37 on: January 23, 2015, 09:17:22 PM
I'd like to know too  :think:
Defend the Hive!!!
Reply #38 on: January 23, 2015, 11:20:37 PM
the sisscors as assescoire work great, i made a sisscor in stead of the awl but i don't like that.
because of the flippy-thingy you can scure it in place, yes it rattles a little but it's not irritating.
the sisscor is a bit small but usable, i would like it better when mounted to something..
ca Offline derekmac
Reply #39 on: January 26, 2015, 01:24:06 PM
They don't move at all, even when hammering.  When you look at the pic, the pin stops it from sliding back, and the tan piece stops it from sliding forward anymore.
us Offline tommywp
Reply #40 on: January 26, 2015, 04:40:45 PM
Well, that settles it!  Getting a MUT!!
ca Offline derekmac
Reply #41 on: January 26, 2015, 05:01:56 PM
us Offline buck
Reply #42 on: May 26, 2015, 01:41:53 PM
Sharpen it and use it as an big awl, that's the only thing still missing!
Or, perhaps something to make changeble saws, that Ahold be great to.
I like a good metalsaw!..
I wonder why you couldn't use a Surge saw/file bit holder or maybe that's exactly what you are saying?
« Last Edit: May 26, 2015, 01:43:02 PM by buck »
PM me if you want one of my kidneys for your SOG TiNi multitool.
OK, both my kidneys.
us Offline buck
Reply #43 on: May 29, 2015, 05:15:39 PM
Well I decided that I wanted to have my tweezers, so I did the tweezers mod!
I used the blade on my TTi to make the marks where the material needed to be removed.
I used the blade and the file to give me the room I needed.
And the end result.  Now to figure out what to do next...  :think:
Does that plastic part just snap on/off?
I'm thinking about channeling out the other side to hold the long bit that got replaced by the scissors.  Anyone try that?
ca Offline derekmac
Reply #44 on: May 29, 2015, 05:17:30 PM
I believe there are two screws that you need to remove to take it off.  It's been awhile since I've done it though, and don't have my MUT on me right now.
us Offline buck
Reply #45 on: May 30, 2015, 08:20:34 AM
If anyone knows where these screws are located; better yet, has pictures I'd be obliged.
I thought I'd find a detail mut take down video on youtube but no luck, just the usual self proclaimed pundit reviews.
us Offline tommywp
Reply #46 on: May 30, 2015, 03:11:12 PM
The other one is in the same spot on the opposite side. #8 torx.
us Offline buck
Reply #47 on: May 31, 2015, 11:54:11 AM
Much obliged!
us Offline buck
Reply #48 on: May 31, 2015, 09:19:46 PM
The scissors now takes one of the places of one of the long bits.
bit holder on bottom plastic part only accomodates the short bit which is quite useless because it already has its holder
because it sticks out you can't use the pliers as is
layout, SOG PowerAssist with bit kit helped with the torx
hogging out the back with a dremel makes the long bit fit
Reply #49 on: June 01, 2015, 12:09:14 AM
 :2tu:
us Offline scattergun13
  • Wanna give blood? Run from my K9...
Reply #50 on: June 01, 2015, 06:41:17 AM
Could J-Sews or anyone expound a bit on the dyeing process. Do you boil then add the RIT to the boiling water and if so, for how long? Sorry if this was a stupid question but I want to do this to my MUT and since this tool was gifted to me by the MTO membership, it is one of my most prized possessions and will be with me forever. Already ordered the Swiss scissors for that mod, now I just want to make sure I get the rest of the process right.
Thanks in advance.
Loyalty,
Stew...
" If it was built by matt2silver then I want2buy it...
us Offline buck
Reply #51 on: June 01, 2015, 08:49:57 AM
I am a shooter so I like all the gun tools but without the scissor mod I wouldn't have a mut.
Thanks to tommywp and derekmac!
http://forum.multitool.org/index.php/topic,59598.msg1093911.html#msg1093911
ca Offline derekmac
Reply #52 on: June 01, 2015, 12:41:51 PM
I've been wanting to dye mine as well, but keep forgetting to look for dye. :facepalm:
us Offline tommywp
Reply #53 on: June 01, 2015, 08:04:08 PM
Thanks in advance.
Loyalty,
Stew...
I followed the steps Babola described in Post #225 of http://forum.multitool.org/index.php/topic,29302.msg1043081.html#msg1043081
Worked great!
us Offline Mike 56
Reply #54 on: June 02, 2015, 05:03:11 PM
I put Swiss card Scissors, tweezers and blacked out the plastic on my MUT last night. Fun easy fun mod. I put a small amount of water in a old pan brought it to a boil added a liberal amount of dye I used powdered. After mixing the dye well I lowered the heat to low and put the parts in the dye for 20 min. Turned out great.
Mike
Reply #55 on: June 02, 2015, 05:20:36 PM
Got it. Thanks Tommy and thanks Mike. Off to mod my MUT. Derek you are a bad influence and that is why I like you. :cheers:
Stew...
ca Offline derekmac
Reply #56 on: June 02, 2015, 05:23:13 PM
I do what I can.  >:D
us Offline buck
Reply #57 on: June 03, 2015, 11:38:17 AM
I wonder if anyone has dyed their plastic parts some wonky color.  I'm thinking maybe red but I wouldn't want it to turn out a dark or murky red.  You can't buy extras from LM or can you?  Maybe if you called them and told them you had scraped them up they would mail you some.
Reply #58 on: July 27, 2016, 03:12:19 AM
Very cool idea Dmac :cheers:
Good thread on the MUT :tu:
ca Offline derekmac
Reply #59 on: July 27, 2016, 03:18:51 AM
Thanks P-Diddy!!  :cheers:
