Here's another one to consider. The Gerber Fisherman Tool.http://www.cabelas.com/cabelas/en/templates/links/link.jsp?id=0012500514855a&type=product&cmCat=SEARCH&returnPage=search-results1.jsp&No=36&Ntt=gerber&noImage=0&Ntk=Products&QueryText=gerber&Ntx=matchall&N=4887&Nty=1
If you are going to fish, you don't need a MT. You need stick of dynamite
Are you guys recommending the Pulse because it's cheap and it's a Leatherman? How is it better than the Juice S2?
Thanks for all the great replies. Just to add to my confusion, now I'm thinking about the Skeletool. I just ordered myself the Skeletool CX to test it out. I have to admit, the pliers are not truly needle-nose and it doesn't have scissors. It may not even have the rust resistance of the Spirit (S), but it looks so cool, I'm thinking even my difficult-to-please dad might like it.
I would suggest the regular Spirit also.The pliers are long enough, the tool is built rather thinner than others,so it should be able to get in most fish mouths because hook extraction is very importantand you can open the tool with one hand, very important, fish in one hand, tool in another.Scissors would be nice for fishing, line cutting and such.Personally I'd rather cut fishing line with scissors then a knife, but not necessary.Then like you know, corrosion resistance, which the Spirit excels at.As for the blunt blade, you could always re-profile that, and it doesn't have to be too pointy, just sharp. When I clean fish, I cut the head off first, then gutting next and you don't need a pointy blade.I personally would use a dedicated fixed blade for guttin fish. their usually bigger andbecause your tool is gonna get stinky! and a simple knife is way easier to clean.but your probably wanting to cut his tool needs down, which is nice.good luck and good son!
