Why do you prefer the liner lock to the side lock?I've seen others say that too, but they don't have any examples of when the side lock has failed them where the liner lock would not. The scale on the side lock versions is thicker, that is one thing.How often do you need a saw? I for one, NEVER need it, so if they made a OHO Adventurer or Super Tinker or Climber, I'd have that one instead.
I agree that Vic OHO blades come with a blunt tip. I took the time to examine some in a shop (thankfully, they know I can be a nut and they don't mind). I think they come this way so they can be turned into combo edge blades with less cost. However, that blunt tip is awful on a plain edge IMO. It was one of the the reasons I started this poll: http://forum.multitool.org/swiss-forum/the-vic-111mm-pe-poll/msg702800/#msg702800 ( I realise now that I left the OHO plain edge option out)About the slide-lock, I like it but I feel it can be compromised by a strong percussion on something hard or even a sufficient amount of dirt.
Syph, how do the liner lock Vics compare with the Wenger Rangers? I recall that you thought the Wengers were more robust.
I suppose that if I remade a 111mm Vic with Ti liners and steel pins, that just might be the ultimate.
Quote from: shamus on November 02, 2013, 03:33:24 PMSyph, how do the liner lock Vics compare with the Wenger Rangers? I recall that you thought the Wengers were more robust. The Vics have brass pins and aluminum liners still.
Quote from: Syph007 on November 02, 2013, 03:40:52 PMQuote from: shamus on November 02, 2013, 03:33:24 PMSyph, how do the liner lock Vics compare with the Wenger Rangers? I recall that you thought the Wengers were more robust. The Vics have brass pins and aluminum liners still. I always thought the liners (at least the locking ones) were steel!!!
Quote from: WWW on November 03, 2013, 02:49:56 AMQuote from: Syph007 on November 02, 2013, 03:40:52 PMQuote from: shamus on November 02, 2013, 03:33:24 PMSyph, how do the liner lock Vics compare with the Wenger Rangers? I recall that you thought the Wengers were more robust. The Vics have brass pins and aluminum liners still. I always thought the liners (at least the locking ones) were steel!!!Only the liner lock is steel, the rest are aluminum.
Oh just get an outrider and gain the scissors
