Beer Can Stove.
si Offline lister
Re: Beer Can Stove.
Reply #30 on: December 04, 2013, 03:14:33 PM
I wonder what would happen if you did not make that tiny little hole.  :think:
I think the fire would probably die, I suspect it's for getting oxygen into the can, as the big opening would be closed by a pan/pot that's standing on the stove. Does that make sense?  :think:
I don't think the hole is for oxygen. Alcohol vapours burn outside the stove not insade. I think it is there to prevent buildup of pressure wich would force the alcohol out of the ''fuel dents''. That way you avoid having a fire breathing monstrosity on your hands.  :D
nl Offline bmot
Re: Beer Can Stove.
Reply #31 on: December 04, 2013, 03:27:41 PM
Ah, that also makes sense, yes.  :tu:
england Offline Taxi Dad
Re: Beer Can Stove.
Reply #32 on: December 04, 2013, 03:51:35 PM
Ssssh ! I wanted to see the video  :whistle:
gr Offline firiki
Re: Beer Can Stove.
Reply #33 on: December 04, 2013, 04:00:10 PM
:think: I have often wondered about a makeswift stove. Might be a life saver some day. I'm a little concerned with fuel efficiency though. :think:
 :ahhh
si Offline lister
Re: Beer Can Stove.
Reply #34 on: December 04, 2013, 04:29:19 PM
 :ahhh
Some general information:
http://en.wikipedia.org/wiki/Beverage-can_stove
And another similar idea:
http://en.wikipedia.org/wiki/Buddy_Burner
Re: Beer Can Stove.
Reply #35 on: December 04, 2013, 06:37:29 PM
I've not made one of these yet, looks easier than drilling lots of little holes  :tu:
And I've not set myself alight for ages   :angel:
Re: Beer Can Stove.
Reply #36 on: December 04, 2013, 07:28:05 PM
"go Sparky!"   "go Sparky!"   "go Sparky!"
 :woohoo: :woohoo: :woohoo:
fi Offline AlephZero
  • Smurf smash!
Re: Beer Can Stove.
Reply #37 on: December 04, 2013, 07:44:39 PM
"Hoarder of weirdness,
Always posting random things,
I'm AlephZero" :ninja:
Re: Beer Can Stove.
Reply #38 on: December 04, 2013, 08:18:50 PM
OK, it works.  Pics to follow in a minute. :)
Re: Beer Can Stove.
Reply #39 on: December 04, 2013, 08:32:21 PM
Sadly it was blowing quite hard outside, proving that this is, as we expected, wind sensitive.
So I decamped inside and set things up in the kitchen.  Don't tell my wife. :whistle:  Gives a nice, well defined flame when it's not blowing a gale.
Supports my camp kettle quite well, though I'd be careful about making this very flat, level and stable.
In the end I got a nice cup of coffee. :D
Works as well as many other drinks can stoves I've tried, with the added bonus of being easy to make and only requiring a single can. :tu:
Re: Beer Can Stove.
Reply #40 on: December 04, 2013, 08:35:12 PM
nice job Gareth  :tu:
(I'll bet Tonys is more spectacular with added danger)
Re: Beer Can Stove.
Reply #41 on: December 04, 2013, 10:13:41 PM
That looks good Gareth  :tu:
Those were always fiddly to make but that design makes it simple
I'm in the process of making another Ali drinking bottle stove with lots of little holes, I may be sometime as I'm having trouble with the indestructible paint  ::)
us Offline captain spaulding
Re: Beer Can Stove.
Reply #42 on: December 05, 2013, 12:28:55 AM
Very cool Gareth. Glad to see it worked out well.  :tu: I still need to test mine.
What did you use for fuel?
I'm the milk man!
Re: Beer Can Stove.
Reply #43 on: December 05, 2013, 12:57:53 AM
I was using methylated spirits.  Same stuff that I normally use in my Trangia etc.  Not the cleanest burning fuel, but works well. :)
Re: Beer Can Stove.
Reply #44 on: December 05, 2013, 01:08:25 AM
Great thanks!  :tu:
I was scouring my house for a fuel source and found some 50% rubbing alcohol. Figured I would at least try it........ Stuff wouldn't even take a spark. Completely not flammable. Looks like I need a more pure form of rubbing alcohol.
I'm the milk man!
gr Offline firiki
Re: Beer Can Stove.
Reply #45 on: December 05, 2013, 03:49:56 PM
 :ahhh
Thanks! It didn't even occur to me to check the Wikipedia!
Now, I just might have to try make me one with a certain canister I have in mind  :whistle: Stay tuned.
gr Offline firiki
Re: Beer Can Stove.
Reply #46 on: December 05, 2013, 03:52:28 PM
Hey, nice job, inspiring me to give it a try.
gb Offline Farmman
Re: Beer Can Stove.
Reply #47 on: December 05, 2013, 06:42:31 PM
Its your fault I have just HAD to buy 4 cans (well I may need spares) of JD and coke:-)
Sent from my Hudl HT7S3 using Tapatalk
Re: Beer Can Stove.
Reply #48 on: December 05, 2013, 07:31:30 PM
well done Mark for ''taking one (or 4) for the team!"
 :hatsoff:
Re: Beer Can Stove.
Reply #49 on: December 05, 2013, 11:13:49 PM
Just be careful if you decide to create four empty cans before you start working on the first stove. :whistle:
gb Offline Farmman
Re: Beer Can Stove.
Reply #50 on: December 06, 2013, 09:18:50 PM
Yep mine works better inside too.
« Last Edit: December 06, 2013, 09:25:20 PM by Farmman »
Re: Beer Can Stove.
Reply #51 on: December 06, 2013, 10:27:56 PM
Good work! Glad everyone is trying it.  :tu:
I'm the milk man!
no Offline Grathr
Re: Beer Can Stove.
Reply #52 on: December 10, 2013, 05:57:52 PM
Very cool!  :tu:
I wonder if it will work with Primus burner fuel?  :think:
If it does, it would be a nice backup if the Primus burner breaks on a trip.
  • Benner fan club #003
Re: Beer Can Stove.
Reply #53 on: December 12, 2013, 07:51:16 AM
...I wonder if it will work with Primus burner fuel?  :think: ...
Not a good ideal to use anything but alcohol based fuels -->   :ahhh
gr Offline firiki
Re: Beer Can Stove.
Reply #54 on: December 12, 2013, 11:45:04 AM
Not a good ideal to use anything but alcohol based fuels --> (Image removed from quote.)  :ahhh
The trouble with alcohol based fuels is they provide low thermal output, so one has to carry a lot of fuel or rely on these stoves only in an emergency.
I've got to make me some old fashioned torch heads, you know, tar, pine resin, that sort of stuff.  :think:
Still haven't made my can stove  :-[
de Offline RT1969
  • Straight Silver!
Re: Beer Can Stove.
Reply #55 on: December 19, 2013, 10:31:05 AM
Now I have to give Can Stoves a try, I used a Trangia knock-off until now.
If you want something for an emergency, I would say go with the Schweizer Notkocher 71 (http://survival-mediawiki.de/dewiki/index.php/Schweizer_Notkocher - The text is in German, but the pictures show the design pretty well). It uses Ethanol Jelly, can be put out using the cap, can be refilled after use and comes with a stove-top. It's more reliable and durable, but certainly much more heavy.
Re: Beer Can Stove.
Reply #56 on: December 19, 2013, 07:02:31 PM
That's a useful looking little kit. :tu:
gr Offline firiki
Re: Beer Can Stove.
Reply #57 on: December 20, 2013, 12:21:18 PM
:cheers: Thanks for the suggestion. I don't speak German but I reckon that looks useful. It reminds me of some tray heaters we were using when I was working at a catering company.
 :think: Hmm, I might get me some of those, you never know.
Edit: Welcome to the forums  :MTO:
« Last Edit: December 20, 2013, 12:23:04 PM by firiki »
de Offline RT1969
  • Straight Silver!
Re: Beer Can Stove.
Reply #58 on: December 20, 2013, 02:14:11 PM
It is exactly the same fuel in a can, the only difference being this genious pot stand. I only read about them, but I have to order some before the next outdoor season.
And thank you for the welcome! Hopefully I can take some pics over the weekend and post a proper 'new Member' Thread  :)
Re: Beer Can Stove.
Reply #59 on: December 20, 2013, 04:11:17 PM
My experience with the Notkocher is that it burns really dirty and sooty...like the US issue Diethylene Glycol gel. It's not clean burning like Sterno or other chafing fuel.
I refilled an empty can with Greenheat gel and it worked fairly well...but the can (which had already started to rust on the inside in storage before it was opened) rusted through.
