Quick Draw Bit Set
ch Offline Etherealicer
Quick Draw Bit Set
on: December 04, 2013, 11:01:50 PM
This bit-set is intended to be clipped to your belt. You can pull the 20 bits out (similar to a measuring tape). Pushing the button makes the bits retract into the casing.  It works, though its a bit bulky (80mm in diameter and almost 35mm thick).
I was not sure if I should post this here in the Cheap n' Cheerful section as it seems entirely functional. However, conditions where this is really useful (you move around a lot and use tons of different bits) seem uncommon to me.
* huh1.jpg (Filesize: 116.63 KB)
* huh2.jpg (Filesize: 117.04 KB)
* huh3.jpg (Filesize: 141.93 KB)
Re: Quick Draw Bit Set
Reply #1 on: December 04, 2013, 11:22:28 PM
IT looks cool though. :tu: I like it. :D How much did you pay for it?
Reply #2 on: December 05, 2013, 09:38:23 AM
It was roughly 12 USD me thinks, its also available in red... I bought it at Obi and a quick check showed that they are in Croatia too, so maybe you can get one, or you can pm me your address and I will send you one for X-mas.
« Last Edit: December 05, 2013, 09:41:54 AM by Etherealicer »
Reply #3 on: December 05, 2013, 12:03:20 PM
Thanks for the offer, very nice of you :salute:, but I have an OBI store 10km from me. I'll check it out next time I'm there. :cheers:
I might take you up one the offer though if I'll need something forwarded from CH in the future. :D
us Offline Rs217
  • Please send coffee
Reply #4 on: December 08, 2013, 09:49:23 PM
I think it's very neat  :tu:
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
