Most I've seen with the file is someone reshaping it into an awl.
The Wenger nail file works as a phillips stock w/o modding.
I find the can opener on the Cadet still works pretty well for Philips screws, even though it's a bit smaller than the 93mm piece.
That's true, but the tip is at too acute an angle (too pointy), and bottoms out easily in all but the very smallest Phillips screws.I Dremelled mine (both Wenger and Vic) to match the angles found on the various "flat phillips drivers", most commonly found on Wengers, Leatherman Squirts etc. That angle is 57 degrees or so, fits perfectly, and with a rounding of the tip will fit from very small Phillips through #2's.Bonus: still works as a nail cleaner tip ;-)
I'm wondering if you, or anyone, has a picture of their modded for Philips driver nail files.
