Login
Register
Menu
Home
Help
Forum
Tool Talk
Edged Tools
2013 Spyderco Forum Knife Native5 C41GPGR5
kwakster
18 ·
4527
« previous
next »
Print
Pages:
1
Go Down
kwakster
No Life Club
1,006
on:
December 19, 2013, 10:20:58 PM
The Spyderco 2013 Forum Knife is a reflection of both the deep tradition and commitment to innovation that characterize Spyderco.
It is based on the Native5, the latest evolution of one of our most popular US-made designs.
The full-flat-ground blade is machined from premium CPM S110V steel—an ultra-high-performance, state-of-the-art alloy that includes cobalt, niobium, molybdenum, vanadium, and almost three percent carbon.
Its handle is also highly evolved, featuring full skeletonized stainless steel liners, a stainless back spacer, and a meticulously crafted backlock mechanism that took literally years of R&D to perfect.
The handle is encased in green G-10 scales with a distinctive diamond-cut texture pattern and the liners, scales, and lockbar are all expertly hand sanded for an exceptional fit and finish.
The 2013 Forum Knife will be the first production knife to use this new handle material with its very unique texture.
A polished four-position hourglass clip completes the package, supporting tip-up and tip-down carry on both sides of the body and making the knife’s operation completely ambidextrous.
A shining example of the US factory’s craftsmanship, this unique limited-edition knife is laser engraved on the reverse side of the blade with “Spyderco Forum Knife 2013.”
Specs:
Closed Length: 4.0 (Inches) / 102 (mm)
Overall Length: 6.95 (Inches) / 177 (mm)
Blade Length: 2.95 (Inches) / 75 (mm)
Edge Length: 2.42 (Inches) / 61 (mm)
Blade Thickness: 0.125 (Inches) / 3.2 (mm)
Steel: CPM-S110V stainless
Hardness: +/- 63 HRC
Weight: 3.6 (Ounces) / 102 (Grams)
Grind: Full-flat
Edge Configuration: Plain
Lock Type: Back Lock
Handle: Green Diamond-Cut Textured G-10
R/L/Ambi: Ambi
Clip: 4-position
Origin: Golden, Colorado U.S.A. Earth
Datasheet:
http://www.nsm-ny.com/files/CPM%20S110V.pdf
Raukodur
No Life Club
1,614
Re: 2013 Spyderco Forum Knife Native5 C41GPGR5
Reply #1 on:
December 19, 2013, 10:22:46 PM
That is perhaps the only Spyderco I have seen that I like the shape of.
kwakster
No Life Club
1,006
Reply #2 on:
December 22, 2013, 04:13:15 PM
I'm planning to EDC the knife, but first it needs to be sharpened, as the factory edge sadly wasn't apexed over about an inch, and the complete edge is about as sharp as a butterknife.
Luckily i have a Wicked Edge as well as a set of Paper Wheels to make it right.
The knife is put together very well, and the amount of hand finishing is noticeable.
kwakster
No Life Club
1,006
Reply #3 on:
December 22, 2013, 05:13:31 PM
Yesterday evening i sharpened the knife (with a standard Paper Wheel with 180 grit SiC grit plus another one with 15 micron diamond compound), and all worked out rather well, besides one ever so tiny microchip at the base which appeared after test cutting into the edge of hard desk top layer.
First i reprofiled the factory edge from +/- 30 degrees inclusive to 25 degrees inclusive, which seems to be too low for this steel (when leaned on during cutting into this hard & tough material)
I resharpened it, this time with an edge angle that measures +/- 26-27 degrees inclusive, and now the edge survives the same test without problems.
In contrast to what the last picture shows, in real life the edge looks a bit hazy, but it's quite sharp.
It can treetop the hair on the back of my hand, slice single layer toilet paper, and cut the skin of a tomato without slipping.
I'm thinking about carrying this knife for some time, as from what i've read on various forums S110V should be the most wear resistant stainless steel in the world currently used in production knives.
Also, if i'm not mistaken, Spyderco runs these at 63 HRC, when another manufacturer seems to have run it earlier at only 59 HRC.
AHB
Keeper Of The PowerCut
Admin Team
Zombie Apprentice
16,951
Don't mistake lack of talent for genius.
Reply #4 on:
December 22, 2013, 08:21:10 PM
Very nice knife and great job sharpening it..
Merit Badges
Raukodur
No Life Club
1,614
Reply #5 on:
December 22, 2013, 11:51:07 PM
How much did the knife cost?
jekostas
No Life Club
2,549
Reply #6 on:
December 23, 2013, 12:22:15 AM
Pretty. I like the G10 texturing but I've had bad experiences with Natives.
JAfromMn
Absolutely No Life Club
6,689
Stranger in a Strange Land
Reply #7 on:
December 23, 2013, 12:38:56 AM
Defend the Hive!!!
Schneider
Full Member
115
Reply #8 on:
December 23, 2013, 11:19:35 PM
That's a shiny edge.
Nice knife too.
sawman
9,745
You're amongst friends.
Reply #9 on:
December 23, 2013, 11:39:20 PM
Hey Robert! That Native is my favorite Spyderco. Can you believe that I've not yet had to sharpen mine since I've owned it. In all fairness it gets light use but still razor sharp like when I first got it.
SAW
David
8,937
Reply #10 on:
December 24, 2013, 07:27:55 AM
Looks like you got the Forum Native quite sharp!.
Merit Badges
Zed
Zombie Apprentice
19,555
Reply #11 on:
December 24, 2013, 09:07:18 AM
Very nice Robert
and great job on that edge
Merit Badges
Makaveli
Full Member
135
Reply #12 on:
December 31, 2013, 02:20:04 PM
Quote from: Raukodur on December 22, 2013, 11:51:07 PM
If I recall around $150 directly from spyderco.com. They sold out pretty quick.
Aloha
Global Moderator
Point Of No Return
31,235
Reply #13 on:
December 31, 2013, 04:57:47 PM
I don't know much about Spyderco and certainly not very much in regards to blade steels but WOW that's a fabulous looking knife. I have a native but I cannot believe these are in the same family. The edge you put on that blade is gorgeous to say the least. Glad to hear you will EDC this beauty tho I would probably tuck it away sadly and on occasion only have a play with it.
Merit Badges
AdmSlc
Hero Member
776
adm.slc@icloud.com
Reply #14 on:
December 31, 2013, 05:24:02 PM
That version if the Native is sweet!! I'd love to get my hands in that steel. Great post!
-AdmSlc
Merit Badges
Sazabi
6,397
Reply #15 on:
December 31, 2013, 05:39:23 PM
Kinda related question: Are all Natives now put together with screws, or is the current generation still peened?
kwakster
No Life Club
1,006
Reply #16 on:
January 01, 2014, 01:35:33 AM
The standard FRN-handled Native models are still peened.
I also managed to snag two of these recent versions in CTS-XHP steel, and they are still very nice knives in their own right.
Gadget
Full Member
135
Aussie in Norway
Reply #17 on:
March 28, 2014, 06:58:35 PM
I bought my Native 5 last year......... just a lovely design!
My knife has the laminated blade with CPM S35VN steel, should hold up well too.
I'm with Roukodur, there are a lot of Spyderco knives that are a bit on the ugly side, this one's not one of them!
cheers,
-John
Last Edit: March 28, 2014, 07:05:11 PM by Gadget
Print
Pages:
1
Go Up
Forum
Tool Talk
Edged Tools
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$90.65
PayPal Fees:
$5.47
Net Balance:
$85.18
Below Goal:
$214.82
Site Currency:
USD
28%
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
