I'm a paracorder...well I use to be. One hobby at a time I guess.Use to have a little paracord go pouch (will dig it up to take a pic) and all it was was an earbuds case with threading needle, Zippo, hemostats, and Classic. Didn't need anything else, and the hemostats and needle were used for generally the same purpose and I'd take the hemostats over the needle.So Classic, hemostats, and lighter is all you really need...
when you're use to using certain tools and techniques, its hard to give up those things. Sent from my Nexus 4 using Tapatalk
Quote from: LogicBob on December 20, 2013, 04:24:43 PMwhen you're use to using certain tools and techniques, its hard to give up those things. Sent from my Nexus 4 using TapatalkBy switching over to a SAK you'll be doing just that.I don't believe it'll be drastic in the transitional department... SAKs are like they've always been there TBH.
The important thing, to me, is being able to continue some of the techniques I'm accustomed to. You may notice in the picture in the first post, I use a sort of o-ring/dental pick thing with a bend at the end. I use this like a marlin spike, but also to get under a loop that's too small for my finger and pull to tighten a knot. I'm hoping that, since the marlin spike on the SAK is straight, I'll be able to use it to create some space and then switch to the hook on the back of the SAK in order to pull those loops tight. Yes, its different- two tools in place of one, but I can accomplish the same thing.
