Login
Register
Menu
Home
Help
Forum
Tool Talk
Edged Tools
Question for lock blade users
kirk13
41 ·
3151
« previous
next »
Print
Pages:
1
2
Go Down
comis
Zombie Apprentice
11,227
Re: Question for lock blade users
Reply #30 on:
December 31, 2013, 03:56:28 PM
I think what's Styx said earlier in the thread pretty much sum up what I dislike about a slip joint knife(also where a 'stabbing' motion is needed, like making a hole).
The interesting thing is--if all the 91mm SAK has a duller tip like 'my first SAK' or '111mm Trekker', then I will most likely to think of 91mm SAK blade as strictly a 'cutting' blade vs what I could do with a locking blade.
Comis Gear Youtube Channel
Merit Badges
styx
Absolutely No Life Club
9,607
Reply #31 on:
December 31, 2013, 04:22:12 PM
Lock on a folder is a clumsy knife nut's best friend
Merit Badges
Taxi Dad
No Life Club
2,624
Reply #32 on:
December 31, 2013, 06:39:09 PM
been giving this question some thought while going about my day, see Kirky some of us DO listen to you ! And i'd like to answer the question with a question.
do you mean "why do people need to carry Both locking and non locking blades ?" (at the same time)
i often EDC a multitool with locking blade, not
because
the blade locks specifically but because i like that particular tool, same with my choice of pocket knife. i do feel more confident using a lock blade, i like most here i'm sure, have been 'bitten' and still have at least one scar from an unexpected 'closing'
i wouldn't feel i 'need' a Large lock knife to accompany my any of my favourite EDC's. since most of my cutting needs
could
be achieved with a small non locking blade (even a Vic classic or similar) i'd rather have a selection of 'tools' above one large blade. i do however like OHO blades because i often find i want to 'cut' something but only have one hand free. (ie up a ladder holding on for dear life)
Merit Badges
JAfromMn
6,689
Stranger in a Strange Land
Reply #33 on:
January 01, 2014, 02:11:02 AM
I carry a lock blade for cutting construction materials.
its just safer
Defend the Hive!!!
ducttapetech
Zombie Apprentice
18,707
Whiskey Tango Foxtrot, over.
Reply #34 on:
January 01, 2014, 03:23:29 AM
Way more safe.
I also carry one because, my sak or multi just won't handle the task or dulled out fast on a task rather quickly. Having that extra blade is nice. (Jammed up haybine) And yes I have dulled all of my blades I carry in matters of minutes when I have been in the fields tons of times.
sent from Nate's mobile
Merit Badges
powernoodle
5,520
Reply #35 on:
January 01, 2014, 02:31:39 PM
Son saved from mountain lion attack with Spyderco Caly 3.5 (try that with a Classic SD):
http://www.spyderco.com/forums/showthread.php?54132-caly-3-5-vs-mountain-lion
Here's how I see it. We carry this stuff (MTs, SAKs, knives, lights, guns, first aid kits, bug out bags, get home bags, Man Sacks, etc.)
because it makes us feel good to be prepared.
And sometimes, this excessive preparation actually comes in handy. Take the mountain lion as an example.
Its better to have it and not need it, than the converse. Options are good. Just my take. There is some deep psychology going on here that relates to our fears and the train wreck between our ears, but I'll leave it at that.
Merit Badges
Styerman
No Life Club
3,572
Reply #36 on:
January 01, 2014, 09:22:06 PM
Three reasons I cary a folder ; 1) locking , 2) OHO , 3) good steel . I have a few folders ( CRK Sebbie. , and Striders ) , that are close to a FB in overall strength . I the late 80's I got a finger trapped in an industrial accident . Luckily I was found and freed within minutes of the time in which I had decided I'd have to self rescue by self amputating the finger . In 2007 , I had a near miss with a 5/8" drain snake that had grabbed my right hand glove , and tightened it around my right wrist . I was able to open my Vic. OHO rescue ,deploy it , and cut the glove away from the hand .
I believe in OHO folders !
Chris
nate j
No Life Club
3,628
Reply #37 on:
January 05, 2014, 09:23:42 AM
I often carry a non-locking SAK plus a larger OHO locking knife. The SAK typically handles the mundane, day-to-day chores, with the larger OHO knife in reserve in case of emergency. I can think of a number of emergency scenarios (some good examples have already been provided in this thread) in which it might be advantageous to be able to open a knife quickly and with only one hand. And, as Syph points out, if one is going to have a OHO knife, it makes much more sense from design, operation, and safety standpoints for that OHO knife to have some type of lock vs. no lock.
I've considered a FB in place of the larger OHO locking knife, but a FB offering comparable blade length would be less convenient to carry and possibly less socially acceptable. At least around here, a folder clipped in a pocket doesn't get a second look, but a fixed blade on the belt might turn some heads unless one were actually out hunting.
Merit Badges
jzmtl
8,551
Reply #38 on:
January 07, 2014, 02:13:55 AM
The locking folder is also OHO and clipped to pocket, which are the primary reasons. Often I already holding whatever I need to cut in hand and let it go isn't always an option, so I can access, open, cut fold and put back with my other hand.
The SAK is mostly for clean/food/scissors/non-scary use, so I don't actually use SAK blade often.
kirk13
Admin Team
Zombie Apprentice
15,281
Reply #39 on:
January 07, 2014, 10:36:39 PM
Thanks everyone for your input,it's made very interesting reading,and very enlightening in some cases
Merit Badges
PTRSAK
No Life Club
4,758
I'm an Adult?!?! When did that happen?
Reply #40 on:
January 08, 2014, 09:24:05 AM
I REALLY wish that my EDC Alox Electrician was a lockblade of some sort because it closed on my finger today while I was trying to cut some hose and I now have a level 3 ouchie.
it's only because of the location that it didn't need a couple of stitches but it's held together with steri-strip.
Merit Badges
Print
Pages:
1
2
Go Up
Forum
Tool Talk
Edged Tools
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$158.99
PayPal Fees:
$9.20
Net Balance:
$149.79
Below Goal:
$150.21
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
