The Wood Working Thread
derekmac · 144 · 14869
ca Offline jzmtl
Re: The Wood Working Thread
Reply #60 on: January 14, 2014, 04:23:10 AM
Christ, that's more than what I paid for my saw and a bunch of blade.  :P
ca Offline derekmac
  • Little to the right...
Reply #61 on: January 14, 2014, 01:04:19 PM
:D It's not cheap, but I could see it putting a big smile on my face every time I went to cut something!!
I've been thinking about building my own crosscut and 45 sleds, but haven't gotten around to it yet.
Sent from my iPhone 5 using Tapatalk
ca Offline jzmtl
Reply #62 on: January 14, 2014, 11:17:44 PM
I made a small crosscut sled, the biggest problem I had was set it to be REALLY square, because the hardware store squares aren't actually 100% square.  ::)
ca Offline jzmtl
Reply #63 on: January 21, 2014, 03:51:22 AM
Apparently wood glue doesn't hold in -20, now you know.
Reply #64 on: January 23, 2014, 08:30:09 PM
Hmmm, my brain can't seem to figure out how that works...  :think:
I took this today hope it makes more sense  :think:
The pointy end of the wedges could be cut back a bit as you tap that end with a hammer when you want to release the door
ca Offline derekmac
Reply #65 on: January 23, 2014, 08:31:15 PM
Makes perfect sense now! Thanks for the pic. :tu:
Reply #66 on: January 23, 2014, 08:45:02 PM
If you cut the slots and wedges right you can use them to hold fatter or thinner stock  ;)
ca Offline derekmac
Reply #67 on: January 23, 2014, 08:48:06 PM
I really like that!!  I have a bunch of wedges from doing tapered cuts, so all I need to do is notch our some 2x4's and I'm set!  :cheers:
Reply #68 on: April 19, 2015, 10:28:21 PM
The G/F wanted a garden table that she could use for potting up plants and be nice enough to use for entertaining but it had to be ‘rustic’
Well as you know rustic is my middle name  :D
My stock of rescued wood
and old fence posts
Finished it off today  :) and I got to use my new pencil (Thanks Crow  :tu:  )
us Offline SAK Guy
Reply #69 on: April 19, 2015, 10:35:07 PM
Very nice!!!! :2tu:
- Robert
Quo Fata Ferunt
Reply #70 on: April 19, 2015, 10:47:36 PM
Thanks Mate, I am pleased with how it turned out, the materials were free and it earned me some brownie points  :tu:
us Offline SAK Guy
Reply #71 on: April 19, 2015, 10:59:06 PM
It's an A1 job!  :cheers:
- Robert
Quo Fata Ferunt
wales Offline magentus
  • mmmmm SAKrelicious
Reply #72 on: April 19, 2015, 11:03:13 PM
Great job! Go and cash in those brownie points!
Reply #73 on: April 19, 2015, 11:15:05 PM
Now that I like mate :)
Reply #74 on: April 19, 2015, 11:23:43 PM
Not too shabby.  :tu:
ca Offline derekmac
Reply #75 on: April 20, 2015, 12:26:49 PM
Looks good man! :tu:  And you gotta love brownie points!! :D
Reply #76 on: April 20, 2015, 07:25:23 PM
Thanks Guys  :salute:
Mmmm  :think: What shall I spend all those points on  >:D
 :whistle:
Probably be food  :gimme:
Reply #77 on: April 20, 2015, 07:29:19 PM
 :whistle:
Well, you can't really share them with the forum members, right     :P  :D
so be selfish - as you said having some food that is not burned (the sparky cooking method-flambe everything) will be a good change for you   :whistle:
Reply #78 on: April 20, 2015, 07:37:04 PM
 ::)  You burn one breakfast and a couple of t-shirts and no one ever forgets  :facepalm:
Reply #79 on: April 20, 2015, 07:42:01 PM
once something gets posted online, it is there forever   :ahhh
Reply #80 on: April 20, 2015, 07:48:39 PM
Oooh and a coffee table  :whistle:
I should have posted a picture of my 6-pack all those years ago  ::)
Reply #81 on: April 20, 2015, 07:51:46 PM
Reply #82 on: June 21, 2015, 09:27:25 PM
A bit more garage bodgery  ;)
Reply #83 on: July 05, 2015, 12:42:29 PM
Found this on youtube
This guy had a genius idea  :hatsoff:...
Made this to hold Axe handles when working on them with a spoke shave
The extra holes in the sides are so the cam/wheel can be adjusted to take different sized stock
And there’s extra holes in the base for attaching it to other work surfaces   ;)
I might have to remake it as I split the top board when I put the screws in  :-\
fi Offline Crow
Reply #84 on: July 05, 2015, 01:01:55 PM
I saw that one awhile back. My work ara is so small, that i had no use for it. But what you came up with, i might want to copy. Now that is useful. No springs attached?
Reply #85 on: July 05, 2015, 01:16:03 PM
No springs, the wheel/cam just hangs down, push the handle in as far as you want it then pull it towards you, it’s held firm
If you want to plane away from yourself, pull the wheel/cam towards you slide your work in then let the wheel/cam go and it’s locked in
You can’t really see in my pictures but there’s a big bolt at the back holding the jig down
I might give the wheel/cam a try on its own as in the video when I get a min  :think:
Reply #86 on: July 05, 2015, 11:14:57 PM
Side picture of the wheel showing the off centre pivot hole
Reply #87 on: July 19, 2015, 03:59:33 PM
Theres more...
Do you know what it is yet?
They work  :D
« Last Edit: July 19, 2015, 04:01:58 PM by Sparky415 »
Reply #88 on: January 17, 2016, 12:21:55 PM
So I bought this for £20 inc a couple of tools
It was originally a 4 draw ‘chest of draws’ that someone had made into some workshop storage with three little draws on the right and added pair of doors  :tu:
Don’t look too bad, a bit tatty maybe  :shrug:
Old hardboard covered top
Original wood panel top
Remove old rotten beading
Reply #89 on: January 17, 2016, 12:27:11 PM
Clean and ready for new ply top
Turn it upside down, repair damage (garden rocks to add stability  ;) )
Replace bottom ‘skirting’ with cherry skirting
Replace top molding (lots of filler  :facepalm: )
And paint top with grey car primer
« Last Edit: January 17, 2016, 12:53:08 PM by Sparky415 »
Total Receipts: $105.65
PayPal Fees: $6.36
Net Balance: $99.29
Below Goal: $200.71
33%
