Wow, that's a pretty neat old contraption you got there Ray! Sounds like it has about everything built in but the kitchen sink. So in your first photo, what is the purpose of the gray circular area near the left hand end?
Quote from: J-sews on January 12, 2014, 04:56:53 AMWow, that's a pretty neat old contraption you got there Ray! Sounds like it has about everything built in but the kitchen sink. So in your first photo, what is the purpose of the gray circular area near the left hand end?YOU do not have one ?? Hell must be freezing
Quote from: J-sews on January 12, 2014, 04:56:53 AMWow, that's a pretty neat old contraption you got there Ray! Sounds like it has about everything built in but the kitchen sink. So in your first photo, what is the purpose of the gray circular area near the left hand end?Not sure what you are referring to;if you are talking about the circle on the top that is about the size of a dime there is a corresponding one on the opposite side and it's only function seems to be to serve as a finger grip when opening the blades. The small circle at the bottom looks to be for a lanyard loop.
Quote from: Ray S on January 16, 2014, 07:11:09 PMQuote from: J-sews on January 12, 2014, 04:56:53 AMWow, that's a pretty neat old contraption you got there Ray! Sounds like it has about everything built in but the kitchen sink. So in your first photo, what is the purpose of the gray circular area near the left hand end?Not sure what you are referring to;if you are talking about the circle on the top that is about the size of a dime there is a corresponding one on the opposite side and it's only function seems to be to serve as a finger grip when opening the blades. The small circle at the bottom looks to be for a lanyard loop.Yes, sounds like the finger grip area is what I was referring to. I couldn't tell what it was from the photo. Thanks!
