Kampfer's EDC Gadgets
Kampfer · 580 · 72330
Re: Kampfer's EDC Gadgets
Reply #30 on: March 09, 2014, 10:19:23 PM
Very nice kit.
that's us mobile
us Offline captain spaulding
Reply #31 on: March 09, 2014, 10:20:08 PM
Picked up a kershaw select fire today, considering to EDC that from now on
Nope! Not going to happen, love the Surge too much.
Good choice!  :D
I'm the milk man!
us Offline Kampfer
  • Tactical Desk Jockey
Reply #32 on: March 09, 2014, 10:27:39 PM
Alternate setup for lazy days.
us Offline JAfromMn
  • Stranger in a Strange Land
Reply #33 on: March 09, 2014, 10:31:56 PM
Pocket Dump 030914
Nice Carry Lam
One suggestion
I'd like to see you put a small fixed blade or mid to large size folder into your edc
I know you don't need one because the surge has nice oh opening blades.
Its nice to have something to cut the things you WANT and keep the surge ready for the things you HAVE to cut.
 I enjoy my knives. I don't need to carry one because I also always have a multitool tool on me.
 I carry a endura most often. I keep it clean and razor sharp.  Its almost insane what a razor sharp endura will cut through.
 its fun cutting when you know its your edge melting through whatever its cutting through.
I take pride in my knives and what they can do.
I think you may enjoy one also.
Defend the Hive!!!
us Offline Kampfer
Reply #34 on: March 09, 2014, 10:36:38 PM
Noted, will consider.
Thanks, yes suggestion welcome!
us Offline Kampfer
Reply #35 on: March 10, 2014, 03:51:14 AM
I know this is a very unusual approach, I just added a snap off utility knife to my setup.
It is OHO, light as air and stays razor sharp, good for general cutting tasks and fits on side of pouch very well.
I am going give it a few days to see how I like it.
us Offline JAfromMn
Reply #36 on: March 10, 2014, 05:17:42 AM
If you like it you may also like the Gerber eab.
http://www.gerber-tools.com/Gerber-EAB-Pocket-Knife-22-41830.php
I've used the Smurf out if mine.
« Last Edit: March 10, 2014, 05:19:32 AM by JAfromMn »
Defend the Hive!!!
us Offline Kampfer
Reply #37 on: March 10, 2014, 05:19:07 AM
Have one, tried it, very good, but the forum factor doesn't work with my setup.
Reply #38 on: March 10, 2014, 06:39:35 AM
I carry a razor blade in my Wave nylon sheath and on my sheath I carry my Surge in.  A razor for me is a known tool and can be very discrete when needed to be.  I tend to carry them actually quite a lot and used to carry a box cutter but have delegated it to my Micro pouch.
Reply #39 on: March 10, 2014, 04:43:52 PM
Nice! Also doubles as a money clip.
 :tu: :tu:
us Offline Cogito
Reply #40 on: March 10, 2014, 06:31:41 PM
I've been thinking about switching to a new surge for edc, but I'm thinking I might get more uses if I have a modded sidekick (replaceable bit driver, scissors, tweezers, and t-shank adapter) and a modded crunch (replaceable bit driver, awl and dental hook).  What do you guys think?
us Offline Kampfer
Reply #41 on: March 10, 2014, 06:48:05 PM
In a long run, go with the New Surge as long as you found a way to carry the 12oz comfortably, it has everything you could ask for on a MultiTool.
All its wearable tools are replaceable, saw, file, wire cutter etc.
us Offline Kampfer
Reply #42 on: March 10, 2014, 06:55:20 PM
Here is the snap off knife I added, it was 5.25" long so I sawed it down to 4.25".
It weights less than the Swiss+Tech Utili-Key.
« Last Edit: March 10, 2014, 07:03:16 PM by Lam.Kampfer »
us Offline Kampfer
Reply #43 on: March 11, 2014, 01:07:00 AM
I forgot to mention I used Surge's Bosch saw and file to shorten the knife.
Works well.
us Offline Cogito
Reply #44 on: March 11, 2014, 02:16:53 AM
Don't forget to add a metal saw for the t-shank adapter in case you need to do a jailbreak :)
us Offline Kampfer
Reply #45 on: March 11, 2014, 05:13:47 AM
Always have some Bosch blades with me , ;).
nl Offline bmot
Reply #46 on: March 11, 2014, 06:27:46 PM
Did you know the Crunch already has a fullsize 1/4" hexbitdriver?
us Offline Cogito
Reply #47 on: March 12, 2014, 03:39:42 AM
I did not know that :D Will it take LM bits?
us Offline Kampfer
Reply #48 on: March 12, 2014, 03:48:39 AM
Standard bit driver will take any LM bits, but LM bit driver won't take any standard bits.
us Offline Cogito
Reply #49 on: March 12, 2014, 03:53:22 AM
good to know that makes it easier for me later :)  Thx guys :D
nl Offline bmot
Reply #50 on: March 13, 2014, 07:54:41 PM
I'm not entirely sure if it'll be ideal for the flat bits, it might be too deep for them. For hx bits, there's a notch to keep them from sinking into the driver, bit I don't know if that works for the flat ones.
us Offline Kampfer
Reply #51 on: March 13, 2014, 07:56:50 PM
Not ideal, but could work.
us Offline Kampfer
Reply #52 on: March 19, 2014, 01:10:19 AM
Pocket Dump
Reply #53 on: March 19, 2014, 09:29:03 AM
Nice set up. Love that set up for the keys. Gonna try to make one later this week or during the weekend.
that's us mobile
nl Offline Serena
Reply #54 on: March 19, 2014, 10:26:03 AM
Pocket Dump
How did you put those keys together? I would like to have something like that also…
Reply #55 on: March 19, 2014, 11:51:09 AM
He use a small bolt and nut. He put an 8 ring in between the keys so you can hang them on a carabiner or what have you. He email me a while back, showing me how he made it. Pretty good idea I think. Keeps the keys from making noise and the are more compact.
that's us mobile
Reply #56 on: March 19, 2014, 01:02:42 PM
that's us mobile
Kampfer, care to share it here? I think there are a number of folks interested in getting one of those...
 :pok:
Reply #57 on: March 19, 2014, 03:41:00 PM
Kam is a clever guy I'm not surprised he made his key shackle.  True Utility has one that I use and it's pretty nice IMO, it comes with some metal clips as well that have worked great for me.
True Utility TU245 Key Ring System with 5 Key Shackle
http://www.amazon.com/True-Utility-TU245-System-Shackle/dp/B007IOHPRW/ref=sr_1_9?ie=UTF8&qid=1395239877&sr=8-9&keywords=key+ring
us Offline Kampfer
Reply #58 on: March 19, 2014, 05:39:31 PM
I researched on numerous of key organizers available in market, they are expensive and have their limitations.
None can satisfy my needs, because I have a car key and a detachable Utility key i like to incorporate into the setup.
So I decided to make my own, the objectives are ALLCQS (Adaptable, Low-cost, Lightweight, Compact, Quiet & Simple).
I went down to hardware store to pick up a set of stainless steel #8-32 screw and nut, two washers and a sister clip, bolt the keys together, a few drops of super glue on the screw thread at the end. The nut is not going undone itself unless I use pliers.
I am very happy with the end result and I hope you guys will too.
us Offline Cogito
Reply #59 on: March 19, 2014, 10:03:52 PM
That is really clever :)  I like it.
