Now, if you wear skinny jeans, that may not be the case for you! Sent from my iPad using Tapatalk
OHO features (with the main tools, blade, pliers?)A locking blade ( Quick question...this means in the open position, right?)A spring loaded pliers (not necessary)I keep coming back to the skeletool...it just seems mostly what i'm looking for. Except that the needlenose pliers don't look too needlenose...a little flat.Anyways the juice s2 and sidekick also seem like good options, but a couple have suggested to look elsewhere if I need good wire cutters.I noticed the skeletool has a deal that comes with a style cs.All in all, I just need to buy one and try it out.As long as I can use it for something other than a paperweight I';ll be happy.
Wow!I love coming back here each time and having more great suggestions. To answer some questions. I live in the US. My budget is anything under $75. I kind of want a new tool...so that pretty much eliminates retiried tools. Unless there's a place I can get them new. So....now I think I'm needing some thing with OHO features (with the main tools, blade, pliers?)There are models with 4 OHO outside opening tools and all locking. Surge, Wave, Charge for ex A locking blade ( Quick question...this means in the open position, right?)Yes, LM uses liner locks. A spring loaded pliers (not necessary)There arent many models with spring loaded pliers. Wingman, Sidekick, OHT come to mind. I keep coming back to the skeletool...it just seems mostly what i'm looking for. Except that the needlenose pliers don't look too needlenose...a little flat.The Skeletool is a polarizing tool around here with its love it or hate it appeal. I like it and for a simple tool and the bluntish plier is good. This tool is very pocketable and the carabiner give you another option to carry. The Skele and Style deal is a good one and I agree with DMac the style has pretty sweet scissors as well as a nice littel tool in itself. Anyways the juice s2 and sidekick also seem like good options, but a couple have suggested to look elsewhere if I need good wire cutters.The S2 is small, its as small as a Victorinox Tinker. I just got one so I cannot respond it's capabilities but it has always gotten great reviews. I noticed the skeletool has a deal that comes with a style cs.All in all, I just need to buy one and try it out.YESAs long as I can use it for something other than a paperweight I';ll be happy.
The Skeletool pliers are around about the same dimensions as the Juice from this angle, but are actually something like 50% thicker and the pivot is bigger. The Sideclip (not pictured) is a little bit thicker again than the Skeletool but with a slightly smaller pivot and pliers that go down to more of a point.
My next tool (yes I'm already looking for another) will be more robust...maybe the wave.
Quote from: Maliahk on February 16, 2014, 07:03:04 AMMy next tool (yes I'm already looking for another) will be more robust...maybe the wave.In that case, have a look at the new model Surge
SO I got my Skeletool and Style CS in the mail.Much heavier than I thought ( the skeletool not the style)Love the OHO blade.Couple of questions though...THe skeletool looks slightly dirty...not overtly, but around the pliers and carbiner. Is this just from the forging process?Speaking of the pliers, they don't quite close all the way. The tip touches, but the rest of the needlenose section does not...Is this normal?Also a couple of the plates inserted into the handle look slightly worn/chipped...again is this just from forging processes?One more thing, the tool is very stiff, will this go away after use?
Quote from: Maliahk on February 23, 2014, 11:58:55 PMSO I got my Skeletool and Style CS in the mail.Much heavier than I thought ( the skeletool not the style)Love the OHO blade.Couple of questions though...THe skeletool looks slightly dirty...not overtly, but around the pliers and carbiner. Is this just from the forging process?Speaking of the pliers, they don't quite close all the way. The tip touches, but the rest of the needlenose section does not...Is this normal?Also a couple of the plates inserted into the handle look slightly worn/chipped...again is this just from forging processes?One more thing, the tool is very stiff, will this go away after use?Glad you got your Skeletool, a dirty tool very well could be oils and manufacturing crud not cool they let it go thru but a quick clean up and you should be good to go. I know a new squeaky clean tool is very important to some but you mentioned you would be using it on your auto so clean it like you would after a day working with it and it will be good to go. Chipping and worn parts is not normal I'd send it back personally. The needle nose will touch on the tip and this is the precision part of the plier head and is very normal. A very stiff tool is indeed because it's new so go put that tool to some use.
Figured I'd snap some pics for referenceHere are a number of MTs, ordered by thickness left to right, with right being the thickest.Vic Cadet, Leatherman Style PS, Leatherman Micra, Vic Tinker, Leatherman PST II, Vic Farmer, SOG Pocket Powerplier, Leatherman Juice S2, Vic Spirit X, Vic Climber, Leatherman Wingman
Also... kidding is not allowed. I had to do MATH, dammit!
A lot of people seem to be hating on the sidekick/wingmans for some reason, but it is an excellent tool! Those are the only ones with Springed pliers.Also I came to realize when I was looking for multi-tools that you should get them all in metal if possible because plastic will fail on you and that you shouldn't have to rely on the warranty if something does go wrong and they don't cover you. I got my sidekick for $20 on black friday two years ago and it's gone with me everywhere.Not only that they are some of the smallest Leathermans with 2 locking points which is really all you need because the in handle tools when the handles are closed can't close in on themselves so you save the weight of the locking mechanisms. I'm even considering buying a wave so I can take the better tools out of it and put them into my sidekick.As a bonus: right now I'm trying to figure out which elastic band to use because it seems like the sidekick/wingman tools come with a built in place to make them into slingshots! Also I'm working on an idea to lock the handles into slingshot mode, but that might take me some time.
