Clumping Cures
Offline brandonc223
Clumping Cures
on: June 05, 2008, 07:12:23 AM
I've started to notice so minor clumping with my charge. What do you guys do when your tools start to clump, is there a cure, or do you just chuck it up as a minor unconvinced. If it started to get really bad, I may send it in for some tune  ups.
us Offline 665ae
  • Formerly known as 665ae
  • blah blah blah
Re: Clumping Cures
Reply #1 on: June 05, 2008, 07:25:42 AM
First off... Welcome to the forum!
I don't have many miles on my Charge yet, but I haven't noticed any clumping.  I would think the only way to fix it would be to have Leatherman refurbish it, unless you want to try taking it apart yourself.
Re: Clumping Cures
Reply #2 on: June 05, 2008, 08:50:10 AM
Welcome to the Forum mate :)
Unfortunately like Mikey, I just haven't used my Charge enough for and clumping to develope :-\
Re: Clumping Cures
Reply #3 on: June 05, 2008, 12:22:45 PM
I like clumping, so I'd call that a benefit!  :D
A good clean out would be the first thing I would try.
spam Offline scrappy
  • Turd Bucket
Re: Clumping Cures
Reply #4 on: June 05, 2008, 07:36:59 PM
I would use wd40 but I like clumping so ...
Offline brandonc223
Re: Clumping Cures
Reply #5 on: June 06, 2008, 10:10:50 AM
I guess I'm just a hard user! :multi:
Re: Clumping Cures
Reply #6 on: June 07, 2008, 04:21:14 AM
Theoretically, Charges can't clump.  The pivot screw has flats on it that engage a flattened hole in the handles, preventing the screw from rotating. Washers with flats in between the knife blades can't rotate either. All this is supposed to keep the opening motion of one blade from affecting the blade next to it.
Can you describe exactly what sort of clumping you are getting?
Offline Leatherman123
Re: Clumping Cures
Reply #7 on: June 07, 2008, 04:28:40 AM
Maybe the Security Torx bits are loose? maybe you should pick one up!
B
Re: Clumping Cures
Reply #8 on: June 07, 2008, 04:40:30 AM
Shouldn't matter if they're loose, the flats keep it from rotating.  :-\
Offline brandonc223
Re: Clumping Cures
Reply #9 on: June 07, 2008, 05:20:37 AM
We'll after a good cleaning the clumping stopped, but what was happening was when I opened the Large Bit Driver, it drug the can/bottle opener about half an inch out.
Re: Clumping Cures
Reply #10 on: June 07, 2008, 05:31:00 AM
Very strange.
Well, in any case, I'm glad the cleaning took care of it.  :)
ca Offline jzmtl
Re: Clumping Cures
Reply #11 on: June 07, 2008, 06:12:02 AM
My wave does it occasionally too.
us Offline Smitty44
Re: Clumping Cures
Reply #12 on: June 07, 2008, 06:19:30 AM
Welcome to the forums Brandonc223,and glad everything came out OK.
Re: Clumping Cures
Reply #13 on: June 07, 2008, 03:17:58 PM
Best cure for clumping is to buy a Swisstool  :pok:
Dunc
Re: Clumping Cures
Reply #14 on: June 07, 2008, 03:26:45 PM
LOL!
B
Re: Clumping Cures
Reply #15 on: June 08, 2008, 08:18:52 AM
Clumping isn't that bad of a thing helps me to get the tool I want easier on the ones that clump, but glad to hear that you got it fixed up.   :D
