I think fine grit is the way to go and with a little effort should have that red gone in no time.
Ya fine wet/dry sandpaper will take it off pretty easy. Id use 400 or maybe 600 grit. You could use chemical methods but thats messier than needed for this job.
Quote from: Syph007 on March 31, 2014, 08:51:29 PMYa fine wet/dry sandpaper will take it off pretty easy. Id use 400 or maybe 600 grit. You could use chemical methods but thats messier than needed for this job.I'm going to strip it with acid bowl cleaner.its almost impossible to get the coating near the rivets off.
Quote from: JAfromMn on March 31, 2014, 09:57:34 PMQuote from: Syph007 on March 31, 2014, 08:51:29 PMYa fine wet/dry sandpaper will take it off pretty easy. Id use 400 or maybe 600 grit. You could use chemical methods but thats messier than needed for this job.I'm going to strip it with acid bowl cleaner.its almost impossible to get the coating near the rivets off.Had I seen this topic before, that's exactly what I would have told you: the nooks and crevices, especially near the rivets are magnets for the oxidation, and look crappy.I had a well worn PS4, and tried various grit abrasive paper, oven cleaner, a dremel with wire wheels, and also polishing mops. Still it looked a little crappy, even after all that work. I don't think its worth the effort, personally.
Quote from: neillcurrie on March 31, 2014, 10:40:39 PMQuote from: JAfromMn on March 31, 2014, 09:57:34 PMQuote from: Syph007 on March 31, 2014, 08:51:29 PMYa fine wet/dry sandpaper will take it off pretty easy. Id use 400 or maybe 600 grit. You could use chemical methods but thats messier than needed for this job.I'm going to strip it with acid bowl cleaner.its almost impossible to get the coating near the rivets off.Had I seen this topic before, that's exactly what I would have told you: the nooks and crevices, especially near the rivets are magnets for the oxidation, and look crappy.I had a well worn PS4, and tried various grit abrasive paper, oven cleaner, a dremel with wire wheels, and also polishing mops. Still it looked a little crappy, even after all that work. I don't think its worth the effort, personally.I don't like reading that.the acid I'm using is having a effect but its going very slow.hmmmmwhat to do.I think I'm going to have to carefully sand it off with a dremil if oven cleaner don't work at home. well I think I'm gonna to send it to leatherman.while using it writing this post the back spring for the flat driver broke..
change o plans well I think I'm gonna to send it to leatherman.while using it writing this post the back spring for the flat driver broke..
Quote from: JAfromMn on March 31, 2014, 11:26:50 PMQuote from: neillcurrie on March 31, 2014, 10:40:39 PMQuote from: JAfromMn on March 31, 2014, 09:57:34 PMQuote from: Syph007 on March 31, 2014, 08:51:29 PMYa fine wet/dry sandpaper will take it off pretty easy. Id use 400 or maybe 600 grit. You could use chemical methods but thats messier than needed for this job.I'm going to strip it with acid bowl cleaner.its almost impossible to get the coating near the rivets off.Had I seen this topic before, that's exactly what I would have told you: the nooks and crevices, especially near the rivets are magnets for the oxidation, and look crappy.I had a well worn PS4, and tried various grit abrasive paper, oven cleaner, a dremel with wire wheels, and also polishing mops. Still it looked a little crappy, even after all that work. I don't think its worth the effort, personally.I don't like reading that.the acid I'm using is having a effect but its going very slow.hmmmmwhat to do.I think I'm going to have to carefully sand it off with a dremil if oven cleaner don't work at home. well I think I'm gonna to send it to leatherman.while using it writing this post the back spring for the flat driver broke..That sux! I don't know about some of their keychain-sized tools like the P4, just so many problems with them. Luckily the Micra and Style CS seem to be pretty reliable...
Quote from: JAfromMn on March 31, 2014, 11:26:50 PMchange o plans well I think I'm gonna to send it to leatherman.while using it writing this post the back spring for the flat driver broke..Don't do it! The RadioShack E4 I sent it discontinued, you'll get back a PS4, that's it.
Ya the warranty isnt much good if the tools doenst exist anymore and you get a crappy replacement.
They make a es4 http://www.leatherman.com/21.html#start=23I'm going to send it in.they should replace it with one of them.I hope I'm still going to miss the little Phillips of the radio shack
