The Hacked Leatherman Owners Club.
zoidberg · 3532 · 389364
us Offline Tarheelpwr
Re: The Hacked Leatherman Owners Club.
Reply #2070 on: February 01, 2019, 04:50:04 AM
First mod is underway. Hunting tool is apart and ready for action.
My pic is too large to attach.
Reply #2071 on: February 01, 2019, 05:52:50 AM
za Offline Max Stone
Reply #2072 on: February 01, 2019, 07:11:46 AM
Also a few in Apple store. I use Resize It. Let’s see those pics Tarheelpwr  :)
Reply #2073 on: February 01, 2019, 12:37:27 PM
Here’s s start. Might be a while in the making.
This is just the start. Have the pliers out
Reply #2074 on: February 01, 2019, 02:40:50 PM
Nice looking cutter Mr T.  :like:
Did you base your design off an existing cutter?
Reply #2075 on: February 01, 2019, 03:25:44 PM
Nah, it will end up very different. I was watching meat eater on Netflix and when he used a LM saw to break down bones, a lightbulb went off. I already carry a LM hunting, so this will be a half tool specifically for my kill bag.  I don’t want to worry about getting it messy.
Going to keep the serrated/gut hook and Diamond File outer tools.
Inside will be Rebar saw, Rebar awl, and Charge flat driver.
Going to paint the scales Blaze orange Plasti Dip.  It’s a rubber based paint.
I might mess with putting something on the empty plier pivot as well. I know it won’t lock, but might still be useful.
Has anyone removed the “tab” inside the handle of a Charge/Wave?  Does it affect the structural integrity of the frame at all?  I’m going to have to modify either the flat or the frame. Thinking it might be better to modify the frame so I can put something on the other pivot as well.
Reply #2076 on: February 01, 2019, 03:33:56 PM
That’s some serious mods planned Mr T.  :like:
By the tab, do you mean the blade lock pin? It’s only to guide the plier head and lock the blades, no structural benefit. How about a fat chisel/pry bar for the empty plier pivot?
Reply #2077 on: February 01, 2019, 03:43:11 PM
Very nice Tarheel :like: I knocked the tab out of mine as well :cheers: hope you get it the way you want it :tu: mine is still a work in progress as I have stalled on working on it anymore :ahhh need to pick back up on trying to get more tools in the plier end pivot  :salute: I like what you have there though :like: also can't wait to see the paint job :popcorn:
Reply #2078 on: February 01, 2019, 04:07:16 PM
Thanks.
Yes, by tabs I mean the middle guide.
us Offline RobTheRigger
Reply #2079 on: February 02, 2019, 12:37:59 AM
For mods and parts swaps are the Surge and Super Tool 300 EOD compatible/ close in size? I'm thinking Surge EOD. I know it's not economical, but is it possible (without a full machine shop)?
us Offline CallsignBadger
  • Honey Badger Don't Care
Reply #2080 on: February 02, 2019, 04:21:56 AM
They are both the same size. I don’t know how compatable the two’s tools are  :dunno:
nz Offline Syncop8r
Reply #2081 on: February 02, 2019, 10:04:03 PM
The pivot size is the same. I have some ST300 parts in my Surge.
Reply #2082 on: February 03, 2019, 12:56:31 AM
Cool. Thank you! Any clue as to jaw swapability?
Reply #2083 on: February 03, 2019, 01:03:03 AM
If you are talking plier head then they are the same :cheers: The New Surge with replaceable cutters is the same head as the one that the ST300 uses :salute:
nz Offline Syncop8r
Reply #2084 on: February 03, 2019, 01:05:56 AM
I haven't done any plier swaps and don't know anything about the EOD, but I would guess that, like the other parts, Surge/ST300/MUT pliers are compatible with each other and Wave/Charge/Rebar pliers are compatible with each other.
I'm sure someone else more knowledgeable will chime in on this soon...
EDIT: Sooner than I can type, in fact.  ;)
Reply #2085 on: February 03, 2019, 01:12:40 AM
 :hatsoff:
spam Offline Happy Gilmore
Reply #2086 on: February 03, 2019, 01:59:47 AM
I think I agree about removing that little tab inside. You could then eventually put a Rebar Saw/ Straight blade, and awl in there instead of just a flat driver.
Hey Poncho65 can I get a hacker badge?
Cheers,
H.G.
Reply #2087 on: February 03, 2019, 03:01:49 AM
Have you went through the process of requesting one :whistle:
« Last Edit: September 06, 2019, 07:24:25 PM by Poncho65 »
Reply #2088 on: February 03, 2019, 04:53:18 AM
Thank you all!
Reply #2089 on: February 03, 2019, 11:34:45 PM
noooo.....how does one do this mysterious process?  ??? ??? ???
Question, do the internal tools of the surge fit the Wave/charge? I
« Last Edit: September 06, 2019, 07:25:01 PM by Poncho65 »
nz Offline Syncop8r
Reply #2090 on: February 03, 2019, 11:58:09 PM
They can but require a fair bit of grinding/filing. There is more material around the pivot in the Surge/ST300.
EDIT: Link to zoidberg's pics which don't work anymore.  :facepalm:
https://forum.multitool.org/index.php/topic,51510.msg1175267.html#msg1175267
« Last Edit: February 04, 2019, 12:12:54 AM by Syncop8r »
Reply #2091 on: February 05, 2019, 05:30:46 AM
Quick pic of the tool tossed together and the resulting “left over”.  I need to fine tune the mod, but it’s a good start.
Reply #2092 on: February 05, 2019, 05:32:02 AM
Indeed, it is :tu:
Reply #2093 on: February 05, 2019, 05:46:57 AM
Nice half job Tarheelpwr, looking good :like:
Reply #2094 on: February 05, 2019, 05:55:40 AM
 :iagree: :like: :tu:
00 Offline Dutch_Tooler
Reply #2095 on: February 05, 2019, 09:57:48 PM
Cheers!
Dutch_Tooler
Reply #2096 on: February 05, 2019, 10:23:10 PM
Looks good  :tu: :like:
Reply #2097 on: February 08, 2019, 09:03:59 PM
Here's a relatively simple one; a Style PS with scissors removed and a blade added.  Makes it a Style PB perhaps?  Though I'm thinking of it as a Mini Skeletool. 8)
Reply #2098 on: February 08, 2019, 09:05:05 PM
 :like: :tu:
Reply #2099 on: February 08, 2019, 09:10:11 PM
Like it  :tu: :like:
