The Hacked Leatherman Owners Club.
zoidberg · 3597 · 645207
Re: The Hacked Leatherman Owners Club.
Reply #2700 on: December 09, 2019, 05:27:12 PM
Nice mod, Phil :salute: :like:
:nanadance:       :nanadance:
Offline Ivan Perak
Reply #2701 on: December 12, 2019, 08:16:07 AM
From which other Leathermans can i transplant the parts (inserts, pocket clips) to by Rebar?
there are few of broken leathermans running in my local classifieds (Croatia) but i wouldn't throw the cash if it ends up incompatible.
I would like to try this, cheaper option, before springing out for new parts.
Reply #2702 on: December 12, 2019, 09:01:40 AM
Welcome to the boards mate.   :cheers:
Short answer is the locking four inch Leathermans like the Wave, Charge and Blast etc.
The Kick pocket clip and screw is also worth a look.
Offline Ivan Perak
Reply #2703 on: December 12, 2019, 09:35:13 AM
Thanks mate, i will look into that now.
Im not really good with manufacturing my own tools from metal, but fiddling/assembling something from parts is ok with me. Even some grinding/filing/cutting.
I own a Rebar for merely 24 hours now, but i already miss the pocket clip, i dont carry stuff on my belt.
Reply #2704 on: December 12, 2019, 12:20:58 PM
Good luck with modding, Ivan :salute: Hope you can find some great deals :tu:
Offline megapixel
  • New User
Reply #2705 on: December 31, 2019, 07:43:16 PM
Just got a Charge TTi+ for Xmas and I'm looking to add an awl to it. After doing a bit of research I've settled on a Rebar Awl, which should get in today. From what I've read, this should be a direct drop in correct? I think I saw that I should be able to swap it out for the mini driver or scissors.
Is this true or will it require some modification to play nicely? Stoked to be part of such a cool modding community!
gb Offline kingofswords
Reply #2706 on: December 31, 2019, 09:59:41 PM
rebar awl will fit if you swap with large flat head but if you swap with scissors wont close properly(1mm gap or so) if swapped with mini screwdriver then i think you will need to remove plier rest.  both swap with scissors or mini sd will require knife lock to be removed or back of awl grinding i think.
Reply #2707 on: January 01, 2020, 12:29:17 AM
Offline megapixel
  • New User
Reply #2708 on: January 01, 2020, 04:58:50 AM
Thanks for this! Got it installed. Quick question though, do any of your modded tools have vertical blade play? I don't remember it being there before I put the awl in, it isn't much but is definitely noticeable. Side to side is rock solid... The vertical play is noticeable when any tool is locked up.
us Offline Rapidray
Reply #2710 on: January 01, 2020, 06:32:30 AM
Thanks Ray  :hatsoff: but I meant to put this pic  :oops:
The PST is hacked but not in the first pic :facepalm: :D
Reply #2711 on: January 01, 2020, 02:35:16 PM
Nice one Poncho  :like: :tu:
us Offline Rapidray
Reply #2712 on: January 01, 2020, 03:19:18 PM
Well then...that’s a great set up!  :woohoo:
Reply #2713 on: January 01, 2020, 03:31:22 PM
nz Offline Syncop8r
Reply #2714 on: January 01, 2020, 06:58:02 PM
There was a slump in mods last year. Hopefully 2020 will be more modful!
Reply #2715 on: January 02, 2020, 12:54:45 AM
I carried my Wabar, Reave or whatever you want to call it today :D I used it whilst pruning fruit trees and grapes today :cheers: no pics though :facepalm: :oops:
us Offline JBW1
Reply #2716 on: January 02, 2020, 04:53:24 AM
Re- umm fuse??
One of my first mods I did a few years ago.
Reply #2717 on: January 02, 2020, 12:29:08 PM
Great mod, JBW :like:
Reply #2718 on: January 02, 2020, 01:45:58 PM
 :iagree: :like: :tu:
us Offline Rapidray
Reply #2719 on: January 02, 2020, 02:20:55 PM
Nice  :like: :cheers:
us Offline JBW1
Reply #2720 on: January 02, 2020, 03:23:30 PM
Thanks!
I hadn’t carried it in quite awhile, but decided to dust it off and give it some carry time until my Wave gets here :dd:
Reply #2721 on: March 11, 2020, 07:25:18 PM
Bi-Color ST 300 today :cheers:
Reply #2722 on: March 11, 2020, 07:48:58 PM
That looks excellent  :like: :tu:
Reply #2723 on: March 11, 2020, 07:52:56 PM
Thanks Ws :hatsoff:
Reply #2724 on: March 11, 2020, 07:58:47 PM
 :2tu:
Reply #2725 on: March 14, 2020, 05:13:19 PM
Reply #2727 on: March 14, 2020, 05:32:56 PM
Reply #2728 on: March 14, 2020, 05:33:56 PM
Re- umm fuse??
Wouldn't refuse it at all  :like:
00 Offline Sam Lim
Reply #2729 on: March 14, 2020, 06:56:29 PM
Favourite pair at the moment. Light mods. :)
